Where can one get a decent 100-0-100 power transformer, anyway? I looked in the links section but couldn't find any surplus dealers. |
You know what ? you are right man !
I have not been in the links section for a while and I thought I had a surplus electronics dealers section and i don't
I will amend that today.Really an essential parts source for "one of" projects that require expensive parts like transformers and large heat sinks.
first of all you mention you need 100-0-100 for your planned Morgan Jones amp.are you forgetting the heater supply for the tubes
An all-in-one power transformer is best if you want to keep the cost down,the size of the amp tidy and ease the layout requirements.
It can be hard enough getting the layout right in a tube amp with just a single unit but two would be a lot harder if you are doing a one box amp.If two boxes (amp/ps) you can have as many as you need including two 100 volt trasformers with the primaries in parallel and one secondary lead attached to the other as a center tap.this is the electrical equivelant of a single center tapped transformer but again gets into layout and size issues.
brand new I would look at the offerings at
www.tubesandmore.com
They carry the Hammonds,the One Electron transformers and every once in a while small lots of "no names" which are just as good.
For surplus "used" and pulled from equipment check with Surplus Sales Of Nebraska.They recently upgraded the web site and it looks like maybe the prices also went up but still a nice resource for the hard to find or unusual
http://www.surplussales.com/
This joint has a pretty extensive mixed new/nos listing of parts
I found these guys invaluable once when i need to fix a Sony Playstation.The whole drive was cheaper than any repair shop or console replacent.
http://www.mpja.com/
Nice source for high voltage electrolytic caps,dual audio pots,AC adapters and other parts-
http://www.goldmine-elec-.com/products.asp?dept=1222
This place is pretty unique.A bit hard to navigate and you never know what you will find but a great source for the obscure,the unique and for the one of a kind part
http://www.sciplus.com/
there are more but this should keep you busy for a bit
