Question About Watch's "Sapphire Crystal"
May 11, 2007 at 4:45 PM Post #17 of 25
Originally Posted by nickknutson /img/forum/go_quote.gif
I beg to differ..I've seen a lot of scratched crystals, even sapphire crystals. I used to work in the jewelry industry.
to be fair, he was talking about his own watch...all of my watches with sapphire crystal have no scratches on the crystal, just the body.
but i'm sure that crystal can and does scratch...maybe not easily, but i'm not going to rub my watches against the cement to test it
May 11, 2007 at 5:36 PM Post #18 of 25
You can indeed scratch a sapphire crystal. They call it sapphire, it's all corundum. So are the 'rubies' in the movement. Just depends whether you dope the crystal and with what. The only reason they don't use clear corundum in the movement is because it confuses people when they do.
It's just harder to scratch the sapphire cystal than it is to scratch lesser crystals. If you go scraping it against brick, there are plenty of things in bricks that can scratch it. Like more aluminum oxide crystals. But in casual use it will take less damage than glass.
Back in the day, when Rolex could be taken seriously, they used acryllic crystals on all their watches because while easily scratched, they were also easily polished, and they are far less likely to break than sapphire or glass.
fwiw, when they say "mineral crystal" they mean "not plastic" which generally means glass. Not all glasses are alike, and some crystal types, like seiko's hardlex, are quite scratch resistant.
May 11, 2007 at 6:30 PM Post #19 of 25
It's very hard to scratch sapphire as there aren't too many materials harder than it as many members here have mentioned. The only think you need to worry about IMO is cracking and shattering if you bang it against something hard. This is the same concern you have with other classes. That is why some heavy duty military type watches use acrylic glass. Acrylic is much harder to crack and is much more durable, but it scratches very easily.
May 11, 2007 at 6:39 PM Post #20 of 25
No, it's Very Easy to scratch sapphire if you are actually trying to do it. I probably have five things within arm's reach that will scratch it.
but in casual day to day use, much less likely to get a bad scratch.
Just ask any jeweler who fixes watches.
May 11, 2007 at 7:02 PM Post #21 of 25
Yeah, sapphire crystal isn't a miracle force field, but it's durable and tends to look like new if you don't set out to abuse it.
Two of our most expensive watches, Sinn fliegers, are both acrylic because while yes it scratches, it's also really really easy to buff out the scratches... and they're utility watches so it just adds to the flavor.
The rest of the watches in my rotation are all sapphire though.
May 13, 2007 at 1:32 PM Post #22 of 25
Sapphire crystals on watches are man-made.
They are extremely hard, making them very scratch resistant. Subject them to a sharp knock, they can shatter (extremely hard=brittle).
They are rated 9 on the Moh's scale with diamond being the hardest at 10. Mineral crystal comes in at a 5 on the scale. Moh's scale shows the relative hardness of different materials. 10 is harder than 9, which is harder than 5.
So it is not just marketing but is actually quite a tough and scratch resistant material.
Back to the OP. Running it against the wall.......you are on your own there!
May 13, 2007 at 9:13 PM Post #23 of 25
I've had my Seiko watch for about 2.5 years now. It has a stainless steel body/band and a sapphire crystal window. The steel is covered in scratches, the sapphire crystal is completely unscathed.
May 13, 2007 at 9:27 PM Post #24 of 25
They are very scratch resistant but not shatterproof. I say this because I knew a guy who owned a Tag Heuer in school. One of his friends was so fascinated with the sapphire crystal that he kept trying to scratch it with the corner or a padlock. Needless to say, he got a bit over-zealous and cracked it. Ouch.
