K_19
- Sep 29, 2008
This is something I've been wondering for a while... please keep in mind that I'm really horrible as far as my knowledge of science goes
so this may be something obvious to the vets here, but y'know, better to ask and learn rather than be afraid to ask and never know.
So we all enjoy headphones and most of us have dedicated amps... and often we all plug in headphones after the amp is turned on. When you do, with most amps that I've tried, you get that soft "pop" or crackling sound. Often many amps get this as well when you have a headphone plugged in while it's off then you turn them on afterwards. As most amps do this I'm assuming this is not a harmful thing in general. However, I've noticed that there are some amps that don't have this feedback.... some amps in particular from memory that has literally gave zero noise from the jack at all at any time, are amps like M3, and the Violectric V200. Is this due to just difference in design, or are there some sort of muting device integrated into these amps so that it is noise free, and could these in theory possibly compromise the sound? I'm just wondering as I'd think ideally you'd want all amps to be noise free when plugging in, yet I see that some do and some don't. Maybe a cost/benefit issue?
Also another issue I was wondering about that I experienced recently... I got an ELE EL-D02 headamp/DAC and just to take a picture of it I had one of my cheapo earbuds laying around plugged into the headphone jack of the device, but without any sort of power connected to it (so there was no usb cable plugged in). However, I got a pop/crackling noise even if there was no power source at all! Thinking that it was weird, I kept plugging it back in and out (as this was a cheapo earbud I didn't really care about possibly damaging it) and I got the same soft popping sound the first 3-4 times, before it finally became silient from input... does this mean there is possibly some harmful residual leak from capacitors from previous use or something like that? It just seemed weird to me as the device was completely disconnected from its power source, yet it gave me this feedback from the headphone jack... this is a cheapo amp/DAC so I was just concerned if this was a design flaw.
So yeah... in all, if anyone can explain the whole general science behind this soft popping/crackling sound we usually get when we plug in headphones to our amps, it would be greatly appreciated... thanks in advance.
