byronyu
- Jan 28, 2005
Right now i use biwired monster unity audio speaker cables (http://www.ozenterprises.net/_unity/monsterlink.htm) to connect my Apogee Stage speakers to my Krell 400xi.
I'm considering getting another set of speaker cables to increase my guage, but i would need something like the Vampire SB connectors ( http://www.takefiveaudio.com/mall/Sp...nector_sb.html) to fit 2 banana plugs into each speaker post, on both the amp side and the speaker side.
I'm worried about the affect on the sound using the Vampire SB connectors, however. Can anyone comment on whether you think the Vampire SB connector would effect the sound detrimentally? Would i just be better sticking to using one set of speaker cables that have a better contact with the binding post than using 2 sets and having to use the adapter? I know that radioshack connector do affect the sound detrimentally.
thanks
thanks
