Originally Posted by aCuria /img/forum/go_quote.gif
Speakers are a good idea but note I do not have a dac or a soundcard or even a preamp.
Yeah, I noticed -that was why I recommended you to get a DAC (preferably a USB DAC that you can use with both your PC and your CD-player).
I intend to get that asus soundcard soon, am not sure how much of an advantage something like the dac1 will be over that card. |
The Asus Essence STX is a very good card, I currently have the DX but I've tested the STX and will upgrade to it in the very near future. The benefit of getting a external USB DAC is that you will be able to connect your Marantz CD 6000 OSE to it to get a improvement in sound quality. There's some pretty good DAC's that's cheaper than the Asus STX, but equal or better in sound quality. I'm currently researching the
Audiotrak Dr.DAC2 (about $200 on eBay) and the
Audiotrak Prodigy Cube (about $100 on eBay), both of these cards have a supposedly good headphone amp (read reviews and previews in the "portable amp" section) and it's possible to swap the op-amps in both of 'em so you can tweak them to your liking and to match your speakers/headphones.
If I go for something like the dynaudio bm5a, which does not need a preamp, how will the volume control work out of the soundcard? Or will I still need an amp for the volume control. |
Those speakers are pretty good, I've listened to them
But have you looked at the Dynaudio MC15? Those speakers are a variant of the Dynaudio BM15 studio monitors, they are also active speakers so there's no need for a external amp.
What ever active speaker you end up with, you'll use the Windows volume slider to alter the sound level if you connect the speakers to the Asus card or the volume control of the external DAC (if you go that route).
So, to sum it all up: The Asus might be the better choice if you only like to use your computer as a source, but a external DAC would be better as you could both use it with your existing CD-player and other computers that you might have (a laptop perhaps)
