QDC - Discussion and Impressions Thread
Feb 6, 2023 at 11:31 PM Post #2,611 of 2,693
I guess that's the version with the same polarity as the 2-pin CIEMs. The QDC connectors with the raised bridge have opposite polarities compared to 2-pin CIEMs.
I usually verify the polarities using a multimeter and just check them with the included cables.
Feb 6, 2023 at 11:37 PM Post #2,612 of 2,693
That, too, should ease minds about qdc being used with other cables. I will say, though, reverse absolute polarity makes no difference in sound whereas reverse relative polarity between the left and right channels will. ✌️
Feb 6, 2023 at 11:48 PM Post #2,613 of 2,693
Here’s a picture of the new VX with the flush pin connectors. By the way, I’ve said this before, but the build quality on qdc is superb!
Feb 13, 2023 at 10:26 PM Post #2,614 of 2,693
Hey guys, I just got my new Anole VX and I’m very happy to have it back. One thing different from my previous VX is there’s not the raised bridge where the 2-pin cable connects, the connector is flush with the shell which will ease some user’s mind about switching cables. I reached out to Andrew @MusicTeck about the change and he told me qdc now offers the two different connectors, and he orders only the non-bridge design on QDC models for easier cable swapping. 😁
My wallet is in danger *chuckles*
Feb 21, 2023 at 7:47 PM Post #2,615 of 2,693
Hello everyone,
I want to get some recommendations on ear tips for V14. What ear tips work best for your qdc iems? I have tried Dunu candy, S&S, spinfit, azla xelastec, and softear UC, but none of them work well. Thus I stick to the stock tips now. However, I think there might be something great to try.
Feb 21, 2023 at 8:15 PM Post #2,616 of 2,693
Hello everyone,
Final tips work great for my Tiger! :)
Feb 27, 2023 at 3:51 AM Post #2,617 of 2,693
Thank you for your sharing.
There are two issues I encountered.
Some ear tips mute the sound, and my ear canals are stuffed.
On the other hand, some ear tips can't offer great sealing.
I don't know if I wear the IEMs wrong. Am I supposed to rotate the earbuds into my ear like CIEM?
I do it this way because the shape of the V14 is like pseudo-CIEM.
Feb 28, 2023 at 9:02 PM Post #2,619 of 2,693
Hi everyone, still using the QDC Neptune here lol.
My cable recently got busted and I'm looking to replace it with a light but durable one. I'm aware of the reverse polarity issue - did anyone have any luck finding a nice and affordable aftermarket cable that works with these? Thanks so much!
Mar 1, 2023 at 12:39 AM Post #2,620 of 2,693
Hey, I have the V14 and had the same problem. The solution I found is to poke small holes into the stem of the tips so air pressure has a way to equalize. It's kind of a miss by QDC to not have vent holes in the V14 IMO.
Btw, I'm using the azla sednaearfit light long stem, I prefer those to the xelastec and crystal.
Mar 1, 2023 at 12:40 AM Post #2,621 of 2,693
Tripowin cables sound fine to me. Their C8 is ok if a bit thick.
Mar 1, 2023 at 1:43 AM Post #2,622 of 2,693
There are dozens of affordable cables on Aliexpress with that you can choose WDC connectors! :)
Mar 1, 2023 at 4:52 AM Post #2,623 of 2,693
Thank you for your reply. But QDC says there are four vent holes on both sides. Might be something blocking the holes of my V14.
