QDC anole vx has 2 small holes in the shel casing, need advice!
Jul 26, 2021 at 6:08 PM Thread Starter Post #1 of 7
epck
california
Not sure what to do, would like to either seal them or change to a new shell....
Jul 26, 2021 at 6:13 PM Post #2 of 7
Bondic UV liquid plastic (https://www.amazon.com/s?k=Bondic+LED+UV&ref=nb_sb_noss_2) works great if you just want to seal. It has a similar texture & viscosity as super glue (before curing), but hardens to almost the same consistency & feel of resin. Works much like the UV curing resin used for IEM shells. I've used it on IEMs before with no issues.
Jul 26, 2021 at 6:24 PM Post #3 of 7
thanks alot! yeah I mean just mostly want to seal to prevent any further damage, as for cosmetic i don't really give a crap xd
Jul 26, 2021 at 6:28 PM Post #4 of 7
Bondic UV will work fine then. Take your time and build it up around the edges of the hole until it's sealed up.
Jul 26, 2021 at 7:02 PM Post #7 of 7
They should probably work pretty much the same, but I haven't tried them. I prefer Bondic as it comes complete with the easy applicator & UV light.
