koiloco
- Jun 2, 2013
I don't have a problem with the headband
Yeah me too it's those damn ridges on the headband which are a pain![]()
Chico, can you by chance recognize those pads? Annie's or K712?
Thanks so much for your precious informations!![]()
Like I said, the update was silent enough that AKG's own employees aren't aware of it.
The problem/confusion is ENTIRELY due to them NOT changing the part number once the pads were changed. So now, they all just get thrown in and mixed together, and there's no sorting them apart unless you go in and inspect the pads yourself. I'm doubtful AKG could even tell them apart if you asked them to. I assume that eventually spare K712 pads will replace the batches of the first gen memory foam pads, but I have no idea how long that process will take.
As for trying to talk to AKG about this, the bottom line is: same part number = same part to AKG's eyes. AKG's just going to keep on citing that they have the same part number (and unfortunately, they're RIGHT about that) so it's pointless to try and argue with them about it.
Chicolom, this means that if your Chihuahua eats your K712's pads chances are high that you'll receive two Annie's pads if you order a replacement pair?
