DACs
The last thing I will discuss is full sized DACs. This is for one main reason, and that is that I only had my JH13 FPs and for a bit of the festival the Pure II portable amp to use. Not the best for evaluation DACs with. Not to mention I was spending most of my time listening to portable gear, mainly CIEMs and amp/DAC combo units to use with my macbook. Also to add onto that further, I am incredibly happy with my current Audio-GD Master 7, though I still need to purchase an OffRamp for it. But anyways, there were a few units that I still had to check out.
The first of which was the new PerfectWave Direct Stream DAC from PS Audio. I sat down and plugged in my laptop running Audirvana with iTunes. Took some fiddling to even get it to work, turned out you cant use Integer mode with the Direct Stream’s USB. Anyways, from the first moment I started listening to music, it basically blew me away, the detail, the bass, and the imagine and soundstage. From a technical perspective I will admit I was not expecting much from this thing, it sounded like it was trying to hard. But after hearing it, I will say that I definitely would love to get one in house for several weeks to compare against the Master 7, it was good. Really good. So good in fact that I sat and listened to it for almost half an hour, transfixed with my 13s in ear running through the Vorzuge Pure II.
The only other DAC I listened to was the MSB Analog DAC. I have long wanted to hear an MSB DAC so I was pretty excited and it was only two tables away, though from the same distributor, as the Direct Stream, which would turn out to be a bad thing. Going straight to this unit from that one, made for a bit of a let down. Not that the Analog DAC was bad, it was incredible as well, and I don't necessarily want to say that one is better than the other, but on first impression and which one I remember the most it would have to be the Direct Stream DAC.
Before I wrap up completely onto my best of show. The best of show was for me, without a doubt, the PS Audio PerfectWave Direct Stream DAC, it really did blow me away.
