PS AUDIO: Attack of the Noise Harvesters!
Feb 24, 2013 at 10:39 AM Thread Starter Post #1 of 7
BlackstoneJD
They're back! Out of production for a while but now apparently being relaunched. They work wonders if you use like four or five of em. The trick is to add more until they no longer blink. I borrowed a few from someone I know and had a total of nine installed in different outlets in my entertainment room. No blinking at all at that point, and it really took the edge off of the sound. Also, it dramatically improved the picture on both televisions. I saw the same type of improvement on both sets--just cleaner with more pop. I just know since I gave the harvesters back (I now only have five) neither the picture or sound is as good.
So what is setting them off? No dimmer switches in this building, and the only thing that sets them off is my source computer tower or a laptop when running. It has something to do with hard drive disk access. The components must generate noise but these buggers gobble it up. It may very well be 10 cents of parts inside but kudos to PS audio for creating a cheap product that works!
I never thought just one or two by itself did much of anything.
Feb 24, 2013 at 12:34 PM Post #4 of 7
I never said you should buy one I just said they are back.
Feb 24, 2013 at 10:29 PM Post #5 of 7
Music Direct is having a sale on these Noise Harvesters.  $50 each if you buy three or more.  http://www.musicdirect.com/p-7419-ps-audio-noise-harvester-in-black-ea.aspx
Apr 14, 2013 at 6:44 PM Post #6 of 7
At $50 a pop these are an awesome deal if you are trying to rid your system of some harshness. I am a huge supporter. They just eliminated so much harshness in my system I can play louder, the bass is tighter and punchier, and for once I have no complaints with my headphone setup.
Apr 15, 2013 at 11:16 AM Post #7 of 7
They could make a lot of money by molding an IEC plug & receptacle into it's case©. Then even though this device doesn't do anything, it would be in the proper position for a good filter.
