Proposed amp need help
Dec 11, 2004 at 4:25 PM Thread Starter Post #1 of 3
Smiley Man
hi guys
Here is my very basic plan for the amp i want to build, well, modify:
Basically, i want to rehouse my btech bt928 and its psu in a nice aluminium case with brushed ally knobs etc
and also instead of having an in and out on the back, have 2 inputs wich are switchable via the switch on the front
Does this all sound ok to you? also what sort of transformer would i need? the amp needs 15-18volts 200ma
please bear in mind im in the UK
thanks
Dec 14, 2004 at 6:30 PM Post #3 of 3
just get a dpdt or 4pdt (depending on whether u intend to switch the ground, which i have grown to like) and wire up the two inputs to the on on lugs then the output lugs you wire to the input of the amp
