Problem powering my HD580's
- Thread starter insomniac
insomniac
- May 12, 2003
- Messages
- 2,995
- Reaction score
- 15
Any thoughts or insights?
slindeman
- Jun 25, 2001
- Messages
- 792
- Reaction score
- 11
The HA-1 is a fine amplifier, especially with HD580, but it may not match up well with a portable source such as the D-303.
The HA-1 has a low gain, somewhere near 3. Many portables have their line-out at around .5V RMS, so multiply that by 3 and you are at 1.5V RMS, which isn't intolerably loud with HD580.
Also the HA-1 has a lower than normal input impedance (10k ohm), which may be stressing the D-303 line-out.
Do you have a non-portable source, cd player or dvd player, that you could substitute for the D-303? Then you might get a better idea if it is the HA-1, or its interaction with the D-303, that is giving you the trouble.
- Jan 9, 2003
- Messages
- 3,818
- Reaction score
- 1,236
I'll bet that amp is fine for the 580s.
Portable players' line outs are much weaker than those of full size players. Consumer grade sound cards also have weak outputs. IIRC a typical portable line out may be 0.7 Volts while full size players put out about 2.2V. And even if it gets loud enough a portable just can't compete with a decent full size CDP on sound quality.
Your weak link is your source, it is being seriously outclassed by your amp and cans!
insomniac
- May 12, 2003
- Messages
- 2,995
- Reaction score
- 15
Yeah I've tried it with the line out on various PCDP's but the D303 was the best of the bunch.
So I need a home CD deck to take advantage of the HA-1 plus HD580 combo? That is a bit disappointing. The D-303 stacked on top of the amp made a perfect transportable rig for me.
I have a Revo 7.1 sound card. I guess I will give that a try in this set-up.
I was looking at home decks like the NAD 521 and 541 but those are far from transportable.
Would the Headroom Little or the Gilmore Lite be a better match for my D-303?
00940
- Nov 6, 2002
- Messages
- 4,493
- Reaction score
- 44
changing the gain should be easy. any diyer could do it. Just a resistor swap.
taoster
- Dec 12, 2001
- Messages
- 1,868
- Reaction score
- 10
I am guessing the problem is the 580. They are great sounding phones but are really not your thing. That's why they don't sound loud enough or quite right.
daycart1
Ceremonial old guy, bifocals and all.All the philosophy he can muster can't solve the mysterious double-post.
- Mar 28, 2002
- Messages
- 4,710
- Reaction score
- 12
daycart1
- Mar 28, 2002
Do you like the HD 580 from the head-out? It might be that the 303's op amp is pretty close to the optimum for the rest of the unit.
What about Taoster's suggestion? Do you like the 580 with other setups?
insomniac
- May 12, 2003
- Messages
- 2,995
- Reaction score
- 15
I like the HD580's just fine with my meta42. But it just doesn't seem to sound right with the HA-1.
Also, should I be using the 0 ohm or 120 ohm output on the HA-1.
Anybody know if the Gilmore Lite or Headroom Little would be a better match for my rig?
taoster
- Dec 12, 2001
- Messages
- 1,868
- Reaction score
- 10
0 ohm but it's all up to your ear.
It's funny cos the Porta Corda with 24V PSU and class A biased sounds good with the HD580. I'll go check the volume a little later..
Originally posted by insomniac Also, should I be using the 0 ohm or 120 ohm output on the HA-1. |
Sorry to say this, but it is your source! I have a HD600/HD650 and it is VERY LOUD when you pair HA-1 with higher voltage source (I'm using Sony ES-series and Pioneer Elite SACD players). Even Norah Jones/Sarah Mclachlan can be played at ear-ringging loud at 1/2 to 2/3 way up.
You may want to get an external DAC (quite affordable nowadays) to use optical out (if your PCDP has one) to create a high voltage output that HA-1 requires.
taoster
- Dec 12, 2001
- Messages
- 1,868
- Reaction score
- 10
strange.. it seems to work fine on dej2000, de885 and d11 pcdp
slindeman
- Jun 25, 2001
- Messages
- 792
- Reaction score
- 11
Are you sure that's good advice with a picky bipolar opamp like LM6171? I know Jan in the past has said that if you don't balance the resistor values right you will get a large DC offset into your headphones.
Do you mean with the Porta Corda? It has a higher gain I'm sure since it is meant to be used with portable sources.
Which opamps are in your meta42? I owned the HA-1 for quite awhile, and have used meta42's with 5 different opamps. I would describe the HA-1 as a detailed amp that focuses more on the midrange. It is a little weak in the bass, IMO, and overall is a very clean sounding amp that just lacks a little punch. I did enjoy it with HD600, although I did sometimes wish for a little more oomph, especially with rock music.
changing the gain should be easy. any diyer could do it. Just a resistor swap. |
strange.. it seems to work fine on dej2000, de885 and d11 pcdp |
I like the HD580's just fine with my meta42. But it just doesn't seem to sound right with the HA-1. |
00940
- Nov 6, 2002
- Messages
- 4,493
- Reaction score
- 44
Well, the modification itself is quite easy.
Choosing the values could indeed be a bit harder. But all the necessary informations are available on headwize ( here especially ).
Originally posted by slindeman Are you sure that's good advice with a picky bipolar opamp like LM6171? I know Jan in the past has said that if you don't balance the resistor values right you will get a large DC offset into your headphones. |
insomniac
- May 12, 2003
- Messages
- 2,995
- Reaction score
- 15
Thanks for the suggestions but I'm not looking to start fiddling with my HA-1. Not much of a DIY'er yet and I don't want to do anything to risk it's resale value, because as it looks now, I may sell this thing off.
I will try hooking it up to my Toshiba SD-4900 DVD player.
