Ksweene5
- Jul 24, 2015
Hi HF -
I recently got a Pro-Ject Debut Carbon Espirit SB - it has an Ortofon Red installed. I just got around to hooking it up today and I am not hardly getting ANY sound out of it - I get a low listening level even when I turn my amps nearly all the way up. My other turntables are unbearably loud in that second situation, which is why I am so thrown.
I have checked all hookup options I have at my disposal - directly into my vintage Pioneers phono input, into an aux input while using an outboard phono pre, multiple input channels for each of those too. I also hooked it up to my current Yamaha receiver using an outboard pre - still the same.
To double check my equipment I mirrored all of those hookup options but using my vintage Technics - the Technics had no issues - played at a normal volume on all hookup options.
I would really appreciate some insight / advice / troubleshooting - I am really at a loss. TIA
