XenoGears
- Feb 18, 2008
Sometimes the audio will skip and cut out when your working on your computer playing audio.
This is caused by many things but one common remedy is adjusting your PCI latency in the BIOS/setup.
Try to find the PCI latency setting in your bios/SETUP and REDUCE the number, usually the default is 32, try applying a setting of 24, or 16.
If that does not work try increasing the number to 48, or 64.
Sometimes this will solve the problem, if not then you have to adjust the problem in windows and that requires registry editing.
You can find all that information with a google search, "adjust PCI latency windows."
It is different for multiple operating systems and I don't want anybody to follow my advice and get bad results from their registry so getting it from google may give you a better idea of exactly what to do.
