Chef Medeski
- Jan 9, 2005
I'm trying to figure out exactly what I need. I don't know if there is a non-custom amp that can do this. Yet, if there isn't I would still like to know maybe some specs that could help me order a custom amp would help since last time I tried, builders asked for more specifics. So, here is the deal.
I have an iPod connected through a line-out to a FM modulator, a device that breaks the antenna signal and interposes its own. So, it is hardwired into my HU, which is a stock 6-cd changer on an '05 Subaru WRX. So, not to complicated. Well except the FM modulator has a little volume adjuster. So, I've been fiddling around and fount out that having the FM modulator placed at or right below 50% is optimal. Right now I have it at 65-75% because otherwise the volume is too low. Already the volume is too low but distortion really hits in at 80% so I had no choice but to raise it to that level. The other problem is the volume of the HU. Its really not meant to be maxed out, which is my usual setting. It needs to be at about 75% to heavily reduce distortion. So, I need a heavy boost in input volume to allow me to not only listen comfortably but finally to live recordings.
So, I need something with a lot of gain that runs off of either batteries or 12V DC since it is in my car. Now from the set-up I dont know if you can tell but its not the most high-quality system around. So, sound quality is nowhere near as important as merely boosting the signal.
So, if this time around someone could please help me because I really need to purchase this amp, it has been too long I've been stuck with terrible quality in my car. Thanks a bunch for all the help and if anyone wants to build one, just PM me.
