PPA Problems
Jul 12, 2005 at 12:45 PM Post #16 of 18
Originally Posted by Jazper
Don't panic, he was just measuring the music signal
Jul 12, 2005 at 12:48 PM Post #17 of 18
Originally Posted by SSSSSmokey
EDIT: OK, something is definitely effed up. I just disconnected the left channel to see if I possibly had it wired up wrong. However...both channels are still playing without the odd "vocal exclusion" effect. It does sound worse...maybe muddier? No need to respond to this...I'm just posting out my thoughts. I'll probably find it out and fix it before anyone posts a response anyway.
Check your ground connections.
try different opamps
Unlikely.
Sep 1, 2005 at 2:24 PM Post #18 of 18
Got the same left channel voice effect when I switched on my PPA. The error I made was that I swapped the output ground and output left on the Neutrik connector. The thickest pin on the Neutrik is the ground: the one with Rl is right, the other left. Fixed it.
