Juergen
- May 13, 2003
I'm building a PPA and I'm at the point of driling the front/rear panels. For the rear:
RCA Jacks - Digikey CP-1412 ND - 1/4" hole
DC Jack - Mouser 163-1100 - 1/2" hole
Power - Digikey EG 1890 - 3/4" hole
The DC jack flange is extremely close to the shaft diameter so there is very little room to play with but I'm 95% ok with it. The others look 100%
The front will be a challenge. The ALPS pot looks like it needs a 10/32" hole. The Radio Shack blue LED/holder needs 21/64" (or 8.2mm) and the Neutrik jack might work with a 1" but with 1/32" to spare
. My main concern is that if I want the Neutrik jack to align with the ALPS, the lower mounting screw is just about on top of the circuit board. It even looks like this on Tangent's standard panel layout (http://tangentsoft.net/audio/ppa/mis...anels-v0.6.pdf) page 2, top. The ALPS mounts directly to the board so raising it is not an easy option. Has anyone here had a similar problem?
