SparkOnShore
- Oct 26, 2014
So, I can recommend to everybody here Jabra Elite Active 65t! Range is wider than AirPods with my iPhone X. They support AAC codec. Connection is solid at all occasions. They are Bluetooth 5. Sound is bright, but still bass is there, quite balanced overall. You get awesome seal up to the point that you don’t hear anything in a noisy street even without music playing! You want to hear the surroundings? They got you covered with the HearThrough toggle in their sound+ app. There is a 5 band equalizer also in this app! They offer an unbelievable microphone as well as the ability to hear your voice when you speak. They are really comfortable without anything protruding. No lousy over ear hanger, nothing. Just the in ear piece! 15 hours battery, 2 years warranty. IP56 water dust and sweat resistance. You take out one bud, music stops. Nice and small case to put easily in your jeans’ pocket...
I think anymore it’s proven that Apple cannot do it all right! They can produce really nice phones or maybe laptops and iPads (by the way this iPad Pro is really awesome, maybe there is no need for a laptop after that), but as for ear buds I guess they stayed behind and the Beats acquisition did not help that much! When every other manufacturer has turned to the correct concept of wire free in ears that can create a complete seal nesting themselves inside the concha of your ear, as Shure for example was using for the pro musicians on stage, and you refuse to follow, and instead you produce AirPods without any seal and thus zero bass, or huge buds with hangers but again without proper seal, then something is wrong with your desisions!!...
