Voodoochile
Supafly & The Funky Pimps
- Sep 13, 2002
Now that I'm almost finished this PS, I though it fitting to put up some pics. This is my smoothest/quietest PS to date... I keep meaning to post some pics of the smaller single and double units.
This one will end up in a 1-unit rack chassis (13"x8", without the ears) alongside an amp (yet to be named, but some bastardization of the Apheared #47). Possibly evolving into a preamp. On to the ****:
The whole nut.
Hexfred bridge detail.
Rails under load, at uncomfortable volume.
More details- The tranny is a Talema 2A dual 12v sec, which nets an input v of 17v per rail (12v x 1.41 = 17v) after the bridge. The bridge is full-wave, built from eight HFA08TB60 hexfreds, bypassed with .33uF polyester box caps. Regulators are 317/337s, with a 1k feedback resistor, and 25-turn/20k bourns trimpots on the adjust pins. Input pins are bypassed with .1uF tantalum. Both regs are protected with diodes in the event of sudden collapse/reverse discharge of the caps.
The other caps are polyester philips and polypro wimas. I had a 1,000uF panasonic between adjust and ground (again with a diode to discharge to +/- rail) to slow down the turn-on, but it was too slow, so it's out now, I'm going to put in maybe a 220uF cap instead. All electrolytics are panasonic FC, a pair of 10,000uF before and after the regs.
For testing purposes, output is trimmed to 14v, but my intention is to run it at 15.5v. It could deliver 1 amp, but will most likely end up delivering something more like 200ma, as the amplifier is to be buffered with either eight buf634s, or four ha5002s. It is silent, and shows approximately 9mv ripple.
I'll put up some other pics someday when I get this cased up with the amp. Thanks for checking this out... kind of geekish to get worked up over a PS, but I do
The whole nut.
