Power Cables... Really?
Jul 13, 2010 at 7:47 AM Post #391 of 417
Prog Rock Man
How on earth did you come to this conclusion from Currawong's posts????
Because he said this
"No testing of the listening ability of the subjects; no attempt to determine if the components being tested have any electronically measurable differences; no attempt to determine at what threshold a positive result can be obtained (related to the previous points) and the people performing the tests are usually extremely biased and are performing them intent on getting a negative result.  None of this is good science."
To clarify I am talking about the science behind blind testing in relation to audiophile claims to do with power cables in particular and cables in general.
Hifi Wigwam conducted a test where four power cables were disguised with the same sheathing and then set to different forum members who had about a week each to try the cables on their own kit at home. At the end eight of them said they had heard differences between the same cable, as two were identical. None reliably picked out the audiophile cable. That is a well conceived and conducted test with no press influence or deception or religiously held beliefs to somehow falsify the results.
Currawong speaks speculatively and as I quote "None of this is good science". I am speaking of actual testing where there is is very good science.
Jul 13, 2010 at 7:48 AM Post #392 of 417
Lenni
Alternative
isn't this a DBT free forum? why are we discussing dbt topics here?
Mods... anyone there? maybe this thread should be moved there.
there's a whole forum dedicated to the science Ohmies, but you keep posting here.
Jul 13, 2010 at 7:50 AM Post #393 of 417
JamesL
I wasn't asking about IF's.  I'm asking, have YOU ever consistently heard a difference, only to be told that a DBT has demonstrated no difference between the two components that you're consistently hearing a difference between?  It's been demonstrated over and over again, that direct experience all too often leads to a different attitude compared to one based on thinking IF's.  This is why experience is so important.
Before I say anything else, I completely agree with you, though I'd prefer the term 'heavily influence' rather than 'leads to'.
Its not entirely a "IF".  There have been DBT tests that suggested no audible difference in the 'sonic signature' of different power amps.
You're completely right.. that alone.. a few studies whose results were posted on the internet about power amps isn't enough to sway my views, but if for example someone asked me to listen to 2 different amps that were the same internally (and I thought them to sound dramatically different), yes I would, without a doubt open myself to explore that possibility.
Jul 13, 2010 at 7:59 AM Post #394 of 417
aimlink
In medicine, the DBT is held dear, but how it's done is fundamentally different in the majority of trials.
In the DBT's being discussed here, it's the same subject that is asked to detect a difference between two or more cables while they're blinded to which cable is which.
In medical trials, each subject is given only one of the treatments.  So if you're comparing two drugs, you'll have a group of patients given drug X, another given drug Y, and yet another, given placebo.  If you're testing if a particular drug make a difference, then you'll have one group receiving the drug and comparing findings to another group receiving placebo.  In this design, each patient is assessed after their experience with one treatment.
It's not like with cables where each subject is given both drugs on separate occasions and assessed for differences.  This is avoided or impractical for obvious reasons.... in medical testing of therapeutic modalities.
When you confine each test subject to one stimulus, you immediately negate the influence of one stimulus on the other.  You can assess the influence of one stimulus fully isolated from the other.
This is why this methodology is paramount as an essential component to credible medical evidence.  I think it's a very good scientific approach too.
OTOH, with cable DBT's, the same subjects, under test conditions, are being asked to differentiate between two similar stimuli.  Based on this, sweeping conclusions are made?  Am I supposed to roll over and throw out my own personal experience and that of others based on this?   The only real advocates of this are the ones who themselves can't tell a difference even when sited or those who haven't tried it to any meaningful extent.
Jul 13, 2010 at 8:10 AM Post #395 of 417
aimlink
I pretty much share your POV here.  OTOH, I've already expressed my opinion on DBT's where each subject has to compare the different stimuli one after the other under test conditions.  I've read testimonies here where individuals have successfully differentiated cables when blinded.  That's all I need to hear and more power to them.
  The thing that is interesting is that suddenly if you do the same test over and over again, then it's more valid.  Though, I agree that reproduceability is an important component to credible evidence, I would have to challenge this credibility if the test is being conducted in the same way each time.
Jul 13, 2010 at 8:24 AM Post #396 of 417
beeman458
You're chance from randomly guessing STARTS at 50%, whereas in your example, the rate starts at 0%.
Which the fifty percent is automatically, arbitrarily and speciously discounted to zero because the test giver says so as the test has no variance for reality or varying degrees of sensitivity.  Gee, some people have trouble taking a pee while others watch, yet this is both understandable and acceptable as reality has no place in these sorts of trumped up, here's proof, cable test.  Yes, elementary.  It's elementary, only if you can't see the con.
I can't believe you folks haven't been called on this BS earlier by others it's so patently false on it's face.
Jul 13, 2010 at 8:38 AM Post #397 of 417
Fukuoka, Japan
Some of what he has to say holds a lot of truth, but I'm still trying to figure out if he misunderstood uncle erick's post, or if he's just posting a random rant.
The second paragraph was indeed a rant, directed generally, at people with the attitude that because an experiment occurred, that they could make gross generalisations as a result.  I probably should add that I don't think all experiments are bad, I just see a lot of BS here and on audio forums where people claim to be doing good science, which may or may not be true, but then making gross conclusions about things in general which is not science.
Currawong, your post above reads like a rant against the press, science and suggests that there is a devious motive behind testing. Is that really the position that you hold?
Re-read my post again please.  You're only seeing bits of it.  My rant is against bad science and BS conclusions which people make.   I'm not saying this about all experiments or people, just a certain segment. An intelligent person will be able to see clearly whether someone or something falls under my post or not.
I assume here that you're referring to the DBT's comparing audio components and interconnects?  I have serious reservations about them myself.  However, I wouldn't agree that in all these DBT's, the testers are biased.  While I do have reservations about the test designs at times, I also have a fundamental problem with switching back and forth between two very similar signatures and being able to easily and reliably tell the differences while doing so.  I have a problem with it even when doing sighted testing and it's not only with cables.  I am much better able to tell differences when I spend time with one signature and then switch to the other.  It's that one switch over that tells the most.  Once I start doing multiple switches back and forth, the differences are much less discernible.  As to the value of small differences, from experience again, I can say that small differences often make for significant differences in enjoyment over extended listening periods across different genres and different recording qualities.  So I also have disagreements with  those who say that even if there are differences, they they're insignificant and not worthwhile because they are supposedly so difficult to discern in blind testing.
The curious thing is I'm still yet to hear from an anti-cable enthusiast who does hears differences in cables and have willingly admitted that these perceived differences are imagined.  Strong is the believer who has science backing his own personal experience.  Bewildered at science will be the ones who have a convincing experience as any, and are being told by current scientific evidence that it's all in their mind.  For many who experience this, they patiently wait for science to catch up.  Many have persisted and discovered appropriate methods for demonstrating the truth in their experience.  I'm in waiting since it's my belief that the truth lies somewhere in the middle.  There'll always be a lot of contention in and around things that not all are able to perceive.  Ego's will always abound and those who aren't able to perceive something will always claim that if they can't perceive X, then X doesn't exist.
I have much the same attitude. I decided, some time ago, that since it must be "all in my mind" that nothing should happen if i changed power cables.  I was annoyed that, expecting nothing, I got a difference. I would like to know why. So I want more than just "DBTs say it's all in your mind".  I don't buy that, for a great many reasons, ranging from things I've learned about electricity, physics and electronics as well as about my own abilities and limitations and those of people, physically and psychologically.  I'm pretty sure I could create DBTs that people would both pass and fail, with equipment that was both measurably and not measurably different.  Hopefully my rant and this comment will prompt some people to have an intelligent discussion on this.  Might require a lot of input from people who know a lot about electronics, as well about how to properly conduct experiments, though they are probably avoiding threads like this like the plague.
I probably should have added "In all the experiments I have read about, there was..." As for the power cable test, thanks for the example. Got a link to it? What would you conclude from those results?  Yes, I'm going to verbally slaughter you if you get it wrong.
I hope this thread can turn into something more like the 128k vs. lossless thread, where we're actually learning something and experimenting (though obviously with power cables that might be a bit harder to do) than just screaming beliefs at each other.
Jul 13, 2010 at 8:45 AM Post #398 of 417
Head Injury
wat
beeman458, do you have a coin nearby? I want you to flip it 10 times.
heads tails tails tails heads heads tails heads tails heads
How many did I get right? Just to let you know, the ones I got right I predicted using my vastly powerful and unlimited psychic powers. The rest I didn't, for whatever reason. I guess I just didn't feel like it.
Jul 13, 2010 at 8:45 AM Post #399 of 417
beeman458
"see, I told you i'm psychic.  just because I can't choose correctly all the time, doesn't mean I'm not psychic some of the time"
mind blowing...
What I find mind blowing is that folks actually worry about this sort of stuff.  Somebody wants to say they're psychic, I believe them....... and then walk away.  I don't feel compelled to prove or disprove their claim and find it odd that folks bust their butt like they do to prove that someone's a charlatan .  What I find even more interesting is that folks follow the efforts of those who try to do the discrediting.
"Why, I read their book."
"You did?  What, you couldn't have just taken their word for it and walked away?  You actually had to waste your time and read their book to tell you what you're already convenienced of?"
Jul 13, 2010 at 8:54 AM Post #400 of 417
beeman458
Also, phrases like "what a day and night difference!!!", doesn't really lend itself to your 10% theory.
We all know that "all" people are lent to exaggeration but you won't read me writing words like "night and day."  Why?  Because the differences that I hear are very minute and I even have to challenge myself as to what the differences are that I'm hearing but collectively, the changes I make, do make a difference.  I try to do my best to stay out of the exaggerative world.
FWIW, it's about the sum of the parts.  What it's not about, is the individual part being discussed.  If you want the discussion to be about a singular part, drop me from the discussion as that's too finite for me and my dependable sensitivities but if you want the discussion to be about the sum of the parts, SQ and it's emotional impact, count me in.
Example; are you OpAmp rolling on a broken in sound card with a couple hundred hours of use, or a brand new, never been used sound card?  How does a broken in amp affect the sonic chain; SQ and emotional impact?  What's the quality of the electricity being supplied to the sound card and what's the level of the sound cards DAC?  What's the level of the individual's hearing sensitivity; 1db, 1/2db, 0.2db or 0.1db?  Has the sensitivity of the individual's hearing been reliably tested?  Mine pretty much sucks at about a reasonably reliable 1/2db.
Sum of the parts.
Jul 13, 2010 at 9:03 AM Post #401 of 417
beeman458
If someone can only hear a difference 10% of the time (assuming that isn't lucky guesses), then that means there is hardly any difference between cables.
I'll agree with this but in the end, it's about the sum of the parts.  What it's not about is the individual part.
Jul 13, 2010 at 9:06 AM Post #402 of 417
beeman458
You're amazing.  I bow to your psychic prowess.
I have absolutely no trouble with your above example.  If you can do this consistently, more power to ya.  I'm sure you'll do well in the casinos.  And if you don't go to the casinos for ethical reasons, I'll understand.
Jul 13, 2010 at 9:15 AM Post #403 of 417
beeman458
And for those of you who have never taken statistics, you really should.
My business professor, told me I wasn't suited for business.  I've been in business for thirty-one years.  I find it interesting that for all the examples of the numbers of professors that wiff the ball, folks still rely on their prattlings to make themselves feel good about themselves: "Why, I have a degree."
When statistics are applied in an invalid way, no amount of education is going change this point.
How's the saying go, "Lies, damned lies, and statistics."
Jul 13, 2010 at 9:21 AM Post #404 of 417
beeman458
You have mis-used the word reliably here.
No I haven't,
Achieving something 10% of the time is not reliable.
Sure it is as it has a reliability factor of one in ten, but you're welcome to say it's not as it's not about you as it's about my listening pleasure, even if you don't approve of my characterizations.
That suggests I could sell you some thing that only works 1 in every 10 attempts and you would be happy with that and would go on to recommend my product to your friends as reliable. I promise you they would disagree!
Nobody said the cables only works one out of ten times.  What I wrote was that the individual could, as an example, detect the differences one out of ten times because that was the level of their sensitivity due to their noise floor.  It helps to maintain context of what I write.
Sorry, but getting something to work only 10% of the time is actually very unreliable.
Not if it reliably continues to work one out of ten times over many hundreds and thousands of times of use.  It's dependability may suck but it's still reliable in that you know you're going eventually be able to get it to work.
Jul 13, 2010 at 9:25 AM Post #405 of 417
Head Injury
How is it applied in an invalid way? You still haven't adequately answered that. 50% guessing is valid, as I hoped you would have understood from my coin demonstration.
Is it maybe because you're so hung up on the "Who's to say that if he guesses right 1 in 10 times, that one time he did hear it?" First, tests should normally run 20 times, and second a whole argument is not based on one man's results. Look around on the forum, like in Prog Rock Man's thread in the Science forum. There have been many tests done, on many different types of equipment, some with many test subjects, and only a lucky few have guessed above chance.
You're also confused as to the use of the word "reliable". Pay particular attention to definition #2, it applies most to statistics. You're free to believe 1 in 10 is reliable, but I fear for your safety.
Also, five posts in a row. Nice.
