Zorander
Looking forward to your comments.
Originally Posted by Patrick82 The longer the cable is the more it colors the sound. That's why in my system I use as short as possible. Cutting them shorter has saved me $$$$$. |
Originally Posted by Zorander I see. I sort of expected power cables to behave differently from signal and speaker cables (given the relatively high voltage and current they carry). So I assume capacitance -which is reduced with shorter cables- is a negative thing even for mains cables then? Cheers! |
Originally Posted by tourmaline So, a 1 meter cable sounds cleaner then a 2 meter cable? When they are the same make. I have an expensive powercable wich i find too dark sounding on an amp, if i cut it in half, say 1 meter, it could be sounding clearer? |
Originally Posted by Patrick82 Yes. I heard a difference between 1.5 meter and 1 meter PS Audio xStream Statement power cable. But with Nordost Valhalla I didn't hear anything obvious when going from 160cm to 55cm. It's already clean. |
Originally Posted by tourmaline So, if i shorten the powercable to 1 meter, it should be a bit more clear? The 1.8 meter cable is sounding very warm now and it sounds like a dark blanket over it. To shorten the cable might help lift that blanket a bit? I have the idea it is so warm because of the 4 mm2 internal cables used. As i said, from my experiment i learned that 1,5 en 2,5 mm2 internal cables are more focused and clear yet 4mm2 has more body and warmth. |
