Joe Presto
- Oct 2, 2008
That was me indeed!
After a brief search, I found something interesting on instructables, scroll down to see the guts of a remote.
http://www.instructables.com/id/iPod-Inline-Remote/#step1
The remote seems to be quite simple, one wire for the mic, one for the ground, the remote probably creates a brief short-circuit to signal the phone, with each button producing a different number of short-circuits. This should be relatively easy to hack: Cut off the wire (going to the earbud) coming out of the top of the remote (plug hole with a bit of glue?) then strip the rubber sheath from the wire below it, isolate the mic and a ground wire and work that into a custom wire set-up with a trrs connector, ultimately attaching the remote to the sheathing for instance. Would require some creativity, but this way you have a remote+mic and still have the ability to use proper quality cables.
That should work too if that cable is suitable to you, alternatively the Ultimate Ears TF10vi replacement cable should do the trick too, 30 dollars, slightly cheaper, though I have no idea how it compares to the Shures in terms of quality. https://buy.logitech.com/store;jsessionid=2F36EEB6D5A9200EBF44AC5DB051D1CF?Action=DisplayPage&Locale=en_US&SiteID=logib2c&id=ShoppingCartPage
- No volume control on this one.
Were you one of the people who won the Facebook giveaway?
I wonder if someone makes iPhone compatible cables that are of high quality. I'd definitely consider doing something custom with them.
That was me indeed!
You can use the cable from Shure earphone.
http://www.amazon.com/Shure-Accessory-Headphones-CBL-M-K-EFS/dp/B0043241X8/ref=pd_cp_MI_3
Just cut the connectors and you got a good quality cable.![]()
Happy modding
