Post your computer specs!~
Sep 7, 2012 at 2:59 AM Post #1,576 of 3,094
Go get a shimian, 27inch IPS using the same panels that dell and apple use, with no bells and whistles for 280 bucks shipped. ive had mine for like 6 months now, and its one of the best computer decisions ive ever made. i cant hardly look at cheapo tft panels anymore.
Agreed, they are the exact same LG panels but a fraction of the cost. Granted, corners are cut elsewhere but the display is going to look brilliant.
Sep 7, 2012 at 3:30 AM Post #1,577 of 3,094
Why on earth would anyone ever get a CRT anymore? Better resolution? Nope. Better size? Nope. Better colors? Nope. Better power usage? Hahahahaha, nope.
You are literally choosing inferior technology over easier to find and likely cheaper technology. This isn't choosing vinyl over FLAC, it's choosing ether for your anesthetic instead of novocaine. Sure, it works, but not nearly as well and is actually bad for you.
Honestly, it depends on what you're going for. The top end LCD panels definitely are top performance, but they also cost a lot and to get a decent resolution you need to go 27" or above. 1900x1200 at 24" isn't really that great. With the older CRTs you can get very similar performance and better resolution, but with a smaller monitor size. Pixel density matters to some people.
Sep 7, 2012 at 5:31 AM Post #1,578 of 3,094
CRT's = bad for your eyes!
Sep 7, 2012 at 5:39 AM Post #1,579 of 3,094
Thanks for the great advice. I would never have thought to consider barebones Korean monitors with Cinema/Thunderbolt displays. The HP w2207 was great for 2007, but after 5 years I do want to upgrade the monitor. Just wondering, but which model do you own, and where did you buy it? The most popular model seems to be the Achieva Shimian QH270-lite. Even at $330 for a perfect pixel model, that's a hell of a price.
i wouldnt worry about the perfect pixel, me and none of my friends who have bought them have had any trouble of even a single bad/stuck/dead pixel without. though if it makes you feel better, do it, its still a ridiculous value. And ive got the QH-270 lite, its amazing.
Ive got an acer 24in cheapo tft thing that i was using till i got it, and i figured i would use it for like IRC and Foobar and run two monitors, but i dont, because i cant stand to look at it back and forth with the IPS right next to it -_-
Sep 7, 2012 at 10:52 AM Post #1,580 of 3,094
!680x1050 is pretty bad at 22" to be honest. Games and HD look fine at a normal 2-3 feet distance, but dvd's...ugh, I have to sit 5-8 feet away from the monitor befor I'm satisfied with the picture.How does a high resolution 2560x1440 27" inch ips panel deal with displaying dvd's? Will they be entirely unwatchable at a normal 3 foot distance?
Sep 7, 2012 at 11:37 AM Post #1,581 of 3,094
That's what my work display is, works pretty fine for me. Granted, a 27" is better (which is what I have at home) but more expensive. As for same resolution, no. CRTs top out at 72ppi, anyway, where most moder LCDs are 96ppi+. There is literally no reason to get a CRT. Worse refresh rate, as well. And, you know, cancer. So... Yeah. CRT if you want worse tech for more money. Good plan.
I have a 24" screen at work (Dell UltraSharp) and it's fine for most of my work. As for the DVD thing... Well, of course. You're blowing up a 640x480 image to 1680x1050! Of course it's going to look like crap! Some systems (not screens, this is done through the OS) can scale up the picture, but it's rarely as good as HD, when not done professionally.
A bigger screen won't help with that. Getting those movies in HD will.
Sep 7, 2012 at 12:20 PM Post #1,582 of 3,094
Who watches movies at 3 feet from the screen? Do you also watch TV from 3 feet away?
Sep 7, 2012 at 6:40 PM Post #1,585 of 3,094
I recently got a U2711, and use it for watching film/tv quite a lot, haven't watched any standard definition content on it yet really, but it's fine for watching stuff on, when watching something on it I'm a couple of feet back, not sure, probably 2-3 and it's good.
Current specs are a llano based setup, with a GTX570, 256gb M4, 4 x 2tb hdds, Asus Xonar Essnce ST (soon to be replaced by an E7/E9 combo) all in a fractal arc mini (cpu cooled by a 240 rad in the roof)
Plugged into that are my monitors: a U2311H in vertical on the left, then a U2711 as my main (in horizontal :p)
Speakers are a pair of SOLO6Cs, headphones are DT770 pros.
Keyboard is a KBC Poker with cherry blacks, and mouse is a CMStorm Sentinel Zero-G
However I'm in the process of upgrading, downsizing and going back to air cooling (well, going to use a H70) since it's just less hassle when moving it to/from uni.
Just picked up a Lian Li V351, will be putting a mitx board in (not sure which yet), i7 870, same drives, gpu etc.
Sep 7, 2012 at 6:48 PM Post #1,586 of 3,094
im currently using a asus k53e laptop (got it last year)
intel i5 2410 cpu, 8 gb ram, 750 gb hard drive @ 5400 rpm, and crappy inte hd3000
nothing compared to the computers around here but i got it at $599, which is still a better deal than most of the stuff out there today...
Sep 12, 2012 at 12:24 PM Post #1,587 of 3,094
Current all-rounder/work rig consists of the following:
2x Asus ML239 23" IPS
Asus Xonar Essence ST
Intel i5 2500k (will upgrade to i7 once I get busier/more clients)
Kingwin 850watt modular PS 80+Gold
16gig Corsair Vengeance LP 8-8-8-24
EVGA Geforce GTX 550Ti
2x Samsung 128gig SSD for OS and Programs
2 tb WDEARX 7200rpm and 64mb cache green drive for music only (internal)
2tb WD My Book for movies only
4x 2tb WDEARX 7200rpm and 64mb cache green drives in ProBox for backup purposes
Sep 12, 2012 at 1:13 PM Post #1,588 of 3,094
My First all around/Gaming Rig
intel i5 3550 cpu
AMD Radieon 6950 HD Sapphire OC edition
OCZ 600 Watt psu
8 Gb Corsair Vengance [8-8-8-24]
1 750gb Drive [OS Programs Videos]
1 200gb Drive [More Videos]
1 120gb External HD [Once again more Videos]
1 320gb External HD [Music]
Zowie Celeritas CherryMx Brown Keyboard
1 Corsai M60 Mouse
1 Sony 16" 1024x720 LCD
1 Acer 23'' 1920x1080 WideScreen LCD  {primary display}
And within about 6-7 months I'm looking to sell this and build another!
Sep 17, 2012 at 3:56 AM Post #1,590 of 3,094
intel i5 3550 cpu
OCZ 600 Watt psu
1 Corsai M60 Mouse
Mechanical keyboards ftw!
Sent from my SCH-I535 using Tapatalk 2
