Helmore
- Nov 15, 2009
Do you have a name for your SSMH? I was thinking you should call it the 'tubefish'
Originally Posted by immtbiker /img/forum/go_quote.gif Hey MoodySteve, you bringing that beautiful amp to the NYC Meet, or are you going to hog it all to your self ![]() |
Originally Posted by Helmore /img/forum/go_quote.gif Do you have a name for your SSMH? I was thinking you should call it the 'tubefish' |
Originally Posted by Pageygeeza /img/forum/go_quote.gif Balderon: Your caps scare me!! |
Originally Posted by linuxworks /img/forum/go_quote.gif another case update (major one) for my beta22 and arduino 'volumaster': I had some very good help from 'oneplustwo' (jason) who has a pretty neat woodworking shop at his place ![]() ![]() the bottom base is lined with plastic ABS, as is the front and back panels. I had TAP plastics cut some dollar panels for me and also do the 1/2" radius on the corners. the round holes for jacks were done by me. features: the arduino (half of an LCDuino-1) controls the IR receive (that's the red jewel-like thing on the front panel, 2nd from left) and sends PWM voltage to the motor pot. the arduino also does the latch control for the front bulgin pushbutton (that $25 button!). it debounces the button (won't let you press faster than once a second, for safety) and also maintains the latch for the relay and the led color (the bi-color led in the bulgin goes to blue for speaker-out and red for phones-out; yes, its an output selector). you can also change the output selector via the IR remote control. naturally, there is a nite-mode where you can turn all lights out (on the front panel). the IR remote controls this, too. oh, and the volume pot has a led in it that I (laboriously) mounted myself. took a radio shack knob (sorry!) and drilled a hole thru it, then opened up some room in the back and hot melted a led in there ![]() I will have this with me at the bay area meet, coming up in one week. |
Originally Posted by linuxworks /img/forum/go_quote.gif I did not need another metal base (and I didn't like the shine from metal on the base) ![]() the backplane has all the grounding I need. its pretty hum-free. the base is MDF wood and that looked ugly. a very thin (dressing only) sheet of abs helped with visual contrast (imho). and its very very easy to work with. btw, firmware is at: http://www.netstuff.org/mvc-master/f...r_1_10.pde.txt |
Originally Posted by linuxworks /img/forum/go_quote.gif another case update (major one) for my beta22 and arduino 'volumaster': |
Originally Posted by vixr /img/forum/go_quote.gif here is a CMoy I helped my son build...He did most of the work and I was really happy it turned out well. Its a simple OPA2132 chip with a TLE2426 splitter and tomb's trickle charger... |
Originally Posted by MoodySteve /img/forum/go_quote.gif After over 2 years, and several mishaps, my Bijou is finally done. All casework was done by me, except for the large holes on the top plate, which were cut by a CNC plasma cutter by my good friend Dennis over at O&M Engineering. More details and images will be posted in the Bijou thread. My Bijou follows the 'Regal Mod' BOM, 410µF photoflash output caps bypassed with 1µF Obliggato golds. I used Solen polypropylenes for C1. The attenuator is Alps RK40 and all signal wiring is shielded. The sound is as good as advertised - lush, lively and grand. |
Originally Posted by m1abrams /img/forum/go_quote.gif I think his comment was more in regards to the faceplate and not the base. I think your response speaks loudly about your priorities in your builds ![]() |
Originally Posted by balderon /img/forum/go_quote.gif I have finally completed the casework on my Bijou. I tried many times and could not get a decent shot without the the blue illumination washing out. My original front panel design had included a thin white inlay around the outside perimeter of the panel. My wife suggested I illuminate the border instead. (She strongly recommended I publicly give her credit for that idea! Thank you sweetie ![]() ![]() |
