Post pics of your builds....
Sep 25, 2009 at 11:00 AM Post #5,746 of 9,804
apatN
^ You can fill that enclosure with a nice M3 for me if you want.
Sep 25, 2009 at 4:06 PM Post #5,748 of 9,804
linuxworks
Member of the Trade: Sercona Audio
a JISBOS pair of buffer boards, mounted onto ABS plastic to create a sort of 'module'.
green block is for power supply. each board has a white molex connector; one for input and one for output. the power supply wires run from the board, straight down thru the plastic (thru a grommet) and then to the green term block. an attempt to keep power and signal away from each other.
the 'module' is supported by 4 standoffs that extend from the 4 corners.
not sure what I'm going to do with this, yet; but I'll find some app for it
Sep 26, 2009 at 4:34 AM Post #5,751 of 9,804
fishski13
Member of the Trade: SolderWorksAudio
Originally Posted by linuxworks /img/forum/go_quote.gif
I'm wondering when we'll see hammond cases with cookie graphix (decals?) on them, just as a 'reply' back
be a "green" DIYer and recycle those "chassis".
L.W., when are we going to see an Apple IIc box from you?
Sep 26, 2009 at 1:18 PM Post #5,752 of 9,804
Ferrari
As many other projects I have done in the past, it has to be started somewhere.
This is the kick-off of a new SET amp for my AKG K1000 base on some Russian “craps” from my parts bin and a couple of custom made OPTs.
Still a long way to go through the proto phase, but here is the first pic…
Sep 26, 2009 at 2:41 PM Post #5,754 of 9,804
Ferrari
Originally Posted by Daveze /img/forum/go_quote.gif
Good golly Miss Molly. That's two very large tubes.
Naahh, those tubes are not very large, this is a large tube...
but it is for my next project that runs in the range of 1100V DC and will certainly not work in this design @ approx. 250V.
Sep 26, 2009 at 4:00 PM Post #5,756 of 9,804
the_equalizer
Nice looking 6C33C-B's Ferrari! What is the larger tube ? I'm asuuming it's a power triode ?
cheers!
Sep 26, 2009 at 4:19 PM Post #5,757 of 9,804
Ferrari
cheers!
It’s a copper plate version of the Russian GM70 power triode.
