Possibly low end but best sound headphone suggestions.
May 22, 2013 at 10:34 AM Thread Starter Post #1 of 7
drizzt5
Hello,
I'm looking for some headphones that are comfortable and provide the best sound relative to their cheapness.
Can anyone suggest anything better than these?
http://www.amazon.com/Sennheiser-HD201-Lightweight-Over-Ear-Headphones/dp/B0007XJSQC/ref=sr_1_2?ie=UTF8&qid=1369232638&sr=8-2&keywords=sennheiser+headphone
http://www.amazon.com/Koss-T55959-UR-20-Home-Headphones/dp/B00005N9D3/ref=pd_pgd_B0007XJSQC_B00005N9D3?pf_rd_p=1556364682&pf_rd_s=cp-merchandising-top&pf_rd_t=201&pf_rd_i=B0007XJSQC&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=1W6QWX7WVHKS25CF2Y31
I'm not sure but I think those are big enough to cover my ears without being too large to carry around on trips.
Thanks for any suggestions!
May 22, 2013 at 1:24 PM Post #2 of 7
qzyxya
Threads. I've been looking at headphones like those (though head-fi says that the 202s are worse than the 201s I believe, haven't tried either of them out irl yet myself) and have seen that the JVC ha rx700  and the sr850 looked pretty good. Both are around ~30-50 bucks. I'd love to see what other people think are good, as I can't afford the expensive ATH m50s or any of the other highly recommended ones.
May 22, 2013 at 1:35 PM Post #3 of 7
Vidmaven
Just my opinion but for open cans I would recommend Takstar HI-2050 (Technical Pro HPT990). For closed Gemini DJ HSR-1000.
May 22, 2013 at 10:46 PM Post #6 of 7
Vidmaven
they kind of leave the price range I am looking at, but not by much.
Worth every penny and if you buy the Takstar via Aliexpress it's much cheaper.
Check out this thread for more opinions:
http://www.head-fi.org/t/585356/the-takstar-technical-pro-gemini-greathon-thread
May 23, 2013 at 4:45 PM Post #7 of 7
GaryPham
I've actually been very impressed with Sennheiser HD419s.  For around 35 bucks, they are very comfortable and sound really good.  Only drawback is the dinky cable, but I still think its the best bang for your buck.
