triggrhaapi
so the V5i-D x 2 for $69 from Burson correct?
What is the process to swap them? Never done it before
Correct. It's relatively simple. The top cover uses 2mm hex screws and the bottom cover uses philips head screws. You only need to remove the screws for the front cover. Once that's off, disconnect the battery. Use a chip puller to remove the chips straight up. I used my tweezers and I bent the pins on the original op amps pretty badly and the second chip came out with quite a lot of force so my little tweezers slipped and sliced my left index finger. Do not do that if you can help it. A chip puller is ideal. I couldn't find one locally but amazon sells them. Order both at the same time to save the headache. Once the old chips are out, orient the op amps so the white dot is facing the upper left corner of the socket (that's pin 1) and simply line up the pins with the socket and press gently and they should just pop in. They are held by friction so they are harder to pull out than push in. By quite a lot. Once they're in, plug the battery back in and replace the front cover and you're done. It's not complex or difficult in the least bit, given the right tools.
It's not a project until you bleed right? Right?
