Origen Ru
- Oct 5, 2016
Hi Onik, I am using the B4-X with IEM Shure 846 with very low impedance with no problems whatsoever. Sounds really good. Very light distortion, with a Tube touch. When I am back home in China I will try it with my HD800 with TRRS balanced cable. Will let you know.is the b4-x only for high impedance headphones or does it work with any iems without noise?
OK thanks, I already have a b1 and I m curious to listen to a b4 too..The Aune B1 is a solid state amp (even if it is class A), the similarities are only aesthetic (and the name, the name is similar). It does not sound like tubes, which are a completely different animal.
By the way I got my Little Bear B4 in from the 11/11 sale, I really like it. The difference is more subtle than expected but it's really smooth and musical. Very enjoyable for most genres, but I wouldn't recommend for energetic electronic music and the like.
Today a friend and I were comparing his Schiit Vali 2 and my Little Bear B4. We liked the B4 better on every headphone we tried. I'm very happy so far; on the other hand, he just bought an upgraded tube for the Vali.
This is the description from Aliexpress:What opamps does the B4X use? Are they Singles or are they balanced opamps?
Did ya try it with IEMS??Got my B4-X today.
Really, REALLY liking this little amp. Looking forward to maybe swapping the opamps
so the V5i-D x 2 for $69 from Burson correct?I just finished my B4-X project. I got my Burson V5i-D op amps today and swapped them in for the NE5532s that are in it as stock. The noise floor is no longer an issue and the full range is definitely sounding better at higher volumes with no distortion. I've been listening to it on my Audio Technica ATH-WS1100is' through an Audioquest cable. I used the stock cable from the headphones to connect my phone to the amp's input, which lets me keep the button and microphone functionality, but moves them down the network a bit. It also lets me keep my LG G7 far enough away from the amp to keep it from making noise due to EM interference. No issues now. I also stuffed a couple semi-tubular sections of polyurethane under the tubes to keep the microphonics to a minimum. It rings much less now while I am walking. I decided not to swap out the tubes for now, since I've gotten the sound to where I wanted it.
