I dont' know how to explain but I have 4 15 Kicker L7 speakers in my car and the bass is fantastic. I want some kind of experience like that.
I can beat them all. trust me on this one...
ok bear with me... ill take you through this step by step... and ill save you lots of money in the process. you have almost everything you need already.
First, buy a red wagon.. a radio flyer..the kind with the flames painted on the side. See if you can upgrade to some oversized knobby rubber tires.
then buy a car battery, or heck make it 2 just to be safe.
get some rope, tie that battery up in the front of wagon good and tight.
next get yourself a couple 4 metal pipes and weld them to the sides of the wagon so they stick up about two or 3 feet in a box around the center of the wagon.
now pull the stereo out of your car, and the speakers.. and all four of those big ol woofers of yours.
bolt the speakers to the posts, stack the woofers in the back of the wagon and use some more of that rope to secure them real tight
now strap that stereo deck right on top of the battery and wire it all up.
there should be just enough space for you to sit in between the battery and the woofers and the 4 speakers can be adjusted to point directly at your ears
Now... the last and most important step. You're gonna need a monkey. Preferebly a chimp because they are easiset to train and dont get violent in their old age.
they are also small (keepin it portable) and quite strong for their size.
train the chimp to pull you around wherever you want to go, to stop for oncoming traffic and various stoplights and signs and what not.
using a stick with a banana hanging from a string in front of the monkey is a good way to keep him going.
Viola. Eye shaking brain melting portable bass, and one bad ass transportation system to boot, and you didnt even have to spend money on new cans.
