Portable CD player with AM, FM, TV sound
Aug 11, 2003 at 12:26 AM Thread Starter Post #1 of 5
ssillcollector
How is the reception? Especially I am interested on TV sound. Is it pretty decent or just a gimmick?
Aug 11, 2003 at 1:07 AM Post #3 of 5
Thanks for the great link. If Dr. Xin Feng likes it, then I'm sure I'd like it too. On my way to the store.
Aug 11, 2003 at 1:54 AM Post #4 of 5
Eh...can't seem to connect to that link (though I think it's just my connection), but I can only assume that's the D-FJ401 that Xin is recommending. BC, that is a very commonly recommended modern PCDP. Probably a good bet.
Aug 11, 2003 at 2:09 AM Post #5 of 5
They've got one that has that on the remote...
it's the D-FJ787, they sell the D-EJ785, which is just like it in europe, I have no idea how it sounds but it uses NiMH rechargeables (R6 size) and has a remote.
there's a pic of the 785 attached
the 787 is 160 bucks at crutchfield (retail price)
up to 15 hours CD playback with included rechargeable batteries (or up to 50 hours with two optional "AA"s)
The G-Protection function can be turned on or off by using a switch under the lid.
Digital Tuner: The D-FJ787 features a built-in digital tuner, located in the supplied in-line remote, with AM/FM/TV and Weather bands. The tuner has a 51-station preset memory, giving you one-button tuning of your choice of 30 FM stations, 10 AM stations, 7 Weather bands, and 4 TV stations. Stations can be preset manually or automatically. You can also select stations by frequency. The ferrite-bar AM antenna is built into the remote control, while the FM/WB/TV antenna is in the headphone cord. For FM tuning, you can switch between Local and DX sensitivity settings.
Batteries: This portable CD player can be powered using the two supplied Sony NH-7WMAA "AA"-sized Nickel-Metal Hydride rechargeable batteries, which can be recharged while in the unit. It can also operate using two optional Sony NH-WM2AA Ni-MH rechargeable batteries, or two optional "AA" alkaline batteries.
Batteries CD Player Radio On
G-Protection On G-Protection Off
Two supplied NH-7WMAA Batteries (charged for about 2 hrs.) 15 hours 10 hours 8 hours
Two optional NH-WM2AA Batteries (charged for about 4 hrs.) 32 hours 24 hours 16 hours
Two Sony alkaline batteries (optional) 50 hours 35 hours 20 hours
