I bought the Mojo in November of last year and didn't realise there were so many choices available. I had come from the line of Fiio E17 and E18 portable DAC/AMP and had been using these just with my mobile phone. I decided to upgrade and the only other DAC I had heard of and was seriously considering was the Oppo HA-2.
While doing so research online and via the UK based Hi-Fi website, What Hi-Fi when searching for reviews on the HA-2, I read about this thing called a Chord Mojo and read how it was not only considered their DAC of the year up to £800 but Hi-Fi product of the year Award winner.
Since owning my Mojo and then only once I started using it, came to Head-Fi. I have learnt that other DAC's were available with iFi devices being the other line of DAC's I would have considered had I known about them.
All told not only am I satisfied with my decision but feel having read your review that others too feel the same way about this wonderful device.
My choice was made to reflect my requirements and even knowing now what other options are available and my usage scenarios, I still feel the right choice was made. YMMV
Just discovered this thread... how awesome! Thanks a ton from someone who has owned/auditioned half of these options, and is considering auditioning almost all of the rest!
Very nice comparison. I'm trying to get something for my Westone UM Pro 50 IEM (I'm coming from Sony PHA-1a) and not sure which way to go - either Chord Mojo or iDSD. Other option is just to get Onkyo DAP and have all in one device. The problem is that it is impossible to audition them all.
After reading tons of reviews and opinions it looks like Mojo is the way to go (especially for low impendance headphones like my IEM).
Can anyone tell me how hot the mojo gets? I keep reading "warm" and "hot" and I wonder about the unit life with the battery inside. Quite frankly I also have concerns about leaving something plugged in all the time that has a battery in it too.
It gets warm, but of you use line out then it will become hot, but there is a thermal cut. So no need to worry.
In last 6 months, the Thermal cut happens to me on Lineout level only for 3/4 times.
Wow. Having it cut out on me at all because it got too hot would piss me off. With the success of this unit you'd think they would get rid of the battery and put it in a larger case for home use as an alternative. Thanks for the reply.
To be blunt though (and this sounds stupid I know), I've never had a dac with a volume control and don't understand the concept. How does it work with the amp volume control?
