Audiophonicalistic
Plussound makes some awesome cables. My next cable will probably be from them.
I certainly think so, since I bought 2 cables. They're definitely sturdy construction wise.Plussound makes some awesome cables. My next cable will probably be from them.
Stay updated on PlusSound at their sponsor profile on Head-Fi.
X8 Series Custom Cable for Extruded (UE / QDC / UM)
Wire: Copper (Type 6 Litz)
Braid: Square
LR Braid: Twist
Termination: Oyaide Gold Plated Right Angle
Y-Splitter: PS Rose Gold Aluminum
Slider: PS Rose Gold Aluminum
Dang, that's a beauty. I would really like a right angle pentaconn 4.4, I suppose you don't that as an option?
The right angle pentaconn is a little piece of engineering, but it’s impossible to use it with a 8 wire cable, there is no space to accommodate 8 wires without the risk to damage them.
That's correct, but the one that is commercially available it's a little more tricky to use.afaik the sony-kimber iem cable is an 8-wire that uses a right angle 4.4mm plug.
Hopefully my cables will be delivered today. The combination of Canada Post being on strike and USPS shuffling the package around LA for 3 days has doubled the expected time. Also Canadian Border Services decided to smack me for duties UGH.
Got em today! Im on the hook for 80 bucks come next payday to my folks but they look gorgeous well built and the Tri Copper is a perfect pairing with the Zeus R. Waiting to try GPS with something.We certainly hope it arrives very soon and meets your expectations!
