The-One
- Apr 23, 2006
Hey guys:
I've just bought a pair of Yuin PK1 having remembered that they were really good when I had a weeks trial with them.
However, I had a Xin amp with opamp rolling then, now it's just out of my DAP's headphone jack.
The problem I'm having isn't so much volume rather than sibilance. As I turn it up, the PK1 sounds sharp, piercing. Lower volumes sound crystalline and brittle so... (the good bass is there, it's just there's too much sibilance along with it)
I've been fiddling with my player's EQ for a bit but can't quite seem to get rid of the sibilance while making the PK1 sound rich with overly distorting the bass or making it sound like underwater.
Any tips on which frequencies I should cut and how much? my DAP also allows narrow/normal/wide band and I can change the freq of each band. Otherwise I'll be forced to sell the PK1s straight on as I do not plan to buy portable amps in the future. Thx.
