pls help to choose port amp
Jul 6, 2007 at 7:18 AM Post #2 of 2
Ok, i think im getting quite good at rattling off some of the names of some good portables.
but before I do that please read this thread by Skylab, it has some excellent reviews on some portable amps.
http://www.head-fi.org/forums/showthread.php?t=216903
to look up the price and specs check this thread out:
http://www.head-fi.org/forums/showpo...40&postcount=1
Now for personal recommendation for you to consider that are within your price range:
Xtra X-1 & the Pro version.
iBasso
Minibox-D/E
Storm STB4 (initally above &200 but with a little haggling you can easily get it under $200)
Little Dot Micro+
Mieser Corda MKIII/MOVE
mseed SPIRIT
Now, im just a newb like you (actually even more) they are all based on what skylab and others have reviewed and mentioned from first hand tests. so please take this with a grain of salt.
hope this helps.
