wakibaki
- May 26, 2011
No, the pad doesn't need to be soldered to function, but the amplifier will be less robust and less versatile. My recommendations are designed to produce the best amplifier possible with that chip.
Removal of a faulty AD8397 is barely more problematic when fitted as I recommend. Simply cut through the chip legs one by one close to the chip using a scalpel. Apply heat to the soldered hole on the reverse. The chip will drop off. Collect the cut legs with a hot soldering iron and clean up the pads with solder wick. Job done.
w
Originally Posted by Beftus /img/forum/go_quote.gif
The pad doesn't need to be soldered in order to function
w
