ioimod
- Nov 1, 2009
I've got my hd25-1 ii for half a year and find that the sound is nice but it feels not very "smooth" . It sounds that replacing the cable will help.
A lot of people say Sennheiser Replacement Cable 81435 fits the jack and the headband groove, works fine.
Also someone says it should be Cable 37974
And even more, makes me real confused...
What I want is an inexpensive stock cable fits the jack, groove (so I do not have to invert the caps, but I do not care the two sides are equal-length) and the overall impedance is no more than 100OHMS. Is there any cable fits?
