Pioneer SE-CH9T - Premium In-Ear Headphones
- Thread starter Ivan TT
Voted!
I have the CH9T since a time ago and it's amazing!! Number one favorite in my collection.
I had a small problem with my first pair, began to detach the paint from the capsules, but warranty's Pioneer replaced the defective units with a brand new one and I not had any problems again (crossed fingers).
Slater
Voted!
Any problem with your cables becoming unravelled (untwisted)?
Lurk650
Oh yeah, I think mine were untwisting b/c I use to just wrap the cable around my FiiO M3 when I was too lazy to detach and wrap up. Doing this stretched them out causing them to loosen.
Finally started using a shirt clip on my aftermarket pair and its much better. I'm sure I have the best sounding workout headphones at my gym lol
No problem with the cable. I always carry them well collected and stored in a hard case.
mykeldg
- Sep 3, 2011
I just got the foam tips and boy these do wonders. Improvement in mids is dramatic. Bass is well balanced now and not overbearing also since it is well balanced by the mids. I recommend it over silicone based on the sonic improvements ive gained which is a lot more vs trying out various silicone tips or cables. Highs are perfect since the nozzle is big and does darken the sound like other silicone tips. I found a 5.5mm nozzle from Misodiko and cost a fair bit lower than complys
https://www.amazon.com/misodiko-Replacement-compatible-Bluetooth-Headphones/dp/B01MTSVNO5
Edit: the small foam tips are huge due to nozzle size. I recommend small (medium at max but M is already too big for me)even to people with large earholes.
Some recomended quality mmcx cable compatible with our Pioneer and that isn't excessively expensive? (sub 50$)
I buyed the following (maybe too cheap) and don't tighten the connectors well and the capsules fall.
https://es.aliexpress.com/item/KZ-M...pgrade-Cable-for-SE846-LZ-A4/32822283482.html
pr0b3r
- Mar 18, 2016
Lurk650
Either Espresso or SPC. I have the SPC and have had Espresso, both very good cables. Unfortunately ordering them custom from their site is down due to Monk MassDrop orders.Some recomended quality mmcx cable compatible with our Pioneer and that isn't excessively expensive? (sub 50$)
https://m.aliexpress.com/s/item/32822038909.html
snip3r77
- May 13, 2010
Impressions on the ch9t?
How many impressions you need?
mykeldg
- Sep 3, 2011
Can you confirm the VE SPC fits well with the CH9T? and are there any sonic improvements? I can purchase those from a local shop here and have been pondering to get them.
The ones you indicate don't have an MMCX connector. I imagine you are talking about these other cables in the same store:
https://es.aliexpress.com/store/pro...826.html?spm=a219c.12010612.0.0.d9af641XddmPs
Thanks for help.
Lurk650
@mykeldg I did notice some sonic improvements bc I got balanced 2.5 and my Opus#1 has better balanced output. Some people don't notice a difference. I personally don't like cables with a mic. I do have a $45 cable off Amazon I'm currently using which seems to take the clarity up a notch but isn't the best for gym use
@Aphex72 I was going fast, yes those ones
mykeldg
- Sep 3, 2011
great thanks. I agree with your observation with mic-ed cables. My Sennheiser Momentums have ios and Straight cables. The straight cables have richer mids compared to the ios one.
