Thought I would post some pics of this for your information.
I wanted to get a case for the 300R as obviously we all want to take care of something this pricey.
I found the Dignis website via this forum and looked at the cases online, no mention of a case for the Pioneer but of course they do make one for the Onkyo.
So rather than take the risk of paying for a full price case I looked at the "seconds" section of the website.
These are cases that are not perfect or failed inspection.
So I bought a PU version of the case in black. Saved about $30 over the normal price. Postage was a bit steep but I decided to go for it anyway.
Case arrived this morning and I'm very impressed. Packaging is gloriously over the top!
Two boxes, the case is in it's own little pouch to keep it safe as well.
Here's some pics...
Comes with screen protectors and some protectors for the top as well.
Perfect Fit!
Volume knob lines up fine
Apart from the angled notch in the back of the chassis the 300R fits great.
Fits into the iPhone pouch perfect as well, great from when I'm travelling and just need that extra bit of protection from damage.
Couple of final points. I simply cannot see what makes this a "2nd". It looks perfect to me. There's some very very slight "roughness" on one side. You can't feel it but you can very slightly see it. That's being very very (very) fussy.
The only other thing I can think of is they changed the design. They now have a cutout where the SD card slots are.
The case is not tight fitting, it's snug so the player would certainly never slide out but you can easily remove the player when needed. That's what I needed, as I'm always adding music.
There's some slight padding to the material which makes it nice to hold.
Overall, yes they are pricey but the attention to detail is really good. I'm glad I made the purchase.
EDIT: Sorry images came through full size, I'll try and shrink them later on
