Steve Buck
- Oct 23, 2016
Any screen cover for the xdp100 will fit
As yet there are no cases available except direct from pioneer japan
I would like to share some impressions after 3-4 days of listening experience.
Just for understanding what is my back ground, I owned the following sources in the past:
Fiio X3, X5, ibasso DX50,90, ihifi 760, AK100, 120, sony pha-1a, pha-3, oppo ha-2, VC Vantam 627bm, Valoq 627au.
It is all about the Balanced output in ACG mode with Etymotic ER4SR:
So what I like so far:
- Very detailed sound (one of the most detailed sources on the market IMHO)
- Great channel and instrument separation
- Tight, deep and very textured bass
- No complains on Mids or Highs yet (typical sabre family sound)
- ACG and Stand alone mode
- User interface and ergonomics, styling (Iike it)
My initial thoughts were to use the 300R as a digital transport (via otg) with Vantam Limited in case I do not like it.
So I will keep it as the main source for a while and see.
What about the distortion problems with Tidal and Spotify, detected on several Onkyo DP-X1?
For me, it's absolutely necessary that Tidal Hifi works without any issues, so that's why I haven't chosen (yet) for the DP-X1.
Has this probleem been resolved on the Pioneer XDP-300r, as it seems to be almost the same player as the Onkyo's
RE. Connecting via Mac.
the only ( player connected) option is "android file transfer" a free program. however its so simple as to only be useful up to a point.
it works..sometimes... and has delays in accessing the card contents..quite often will just disconnect from your player . and worst of all once youve got 78 or near to 78 albums then you cant actually scroll down the window to find a free space to drop the folder to. as theres no choice of view options for your files ( you know..details/small icons/large icons etc).. just a folder view that cant be changed.
to be brutally honest.. dont bother, just take the card out and shove it in your mac.
no issues with tidal hifi in the uk...not for me on xdp300r
So, will this play well with the HD 650?
