Armaegis
Modern Modder Man of Manitoba
HTML... uphill, both ways!
- Oct 18, 2009
Cool beans, much appreciated
So I found this roll of roofing repair material in the garage...
I don't know the exact name of the stuff, but it's probably some variant of "peel 'n seal". Anyhow, this kind of stuff has been used as a cheap alternative for vibration damping in cars (the thicker variety of course). I think it's an asphalt based adhesive with a plastic/rubber backing. Just peel the paper off and stick it on. The thin stuff I've got seems just right for headphones. Therefore...
Cutting this stuff was actually rather difficult. The material itself isn't hard to get through, but it sticks to your scissors and makes a mess of things. You have to be careful it doesn't bunch up behind the scissors and pull itself back into the blade as you're cutting.
So anyhow, I cut a ring out and applied it around the edge of the baffle front.
Sound impressions? Bass is cleaner, but yikes I think it got louder too.
Note to self for future modding projects: put micropore tape over the blutak... felt that gets mashed into the putty is messy stuff and makes life difficult
Haha, an unintended benefit to putting tape over the bass vents is that the whistling sound from wind while walking outside has been decreased (probably because, well, now there aren't holes for wind to whistle across).
I need to do this with my HDJ500's. They have vents too, which causes really annoying whistling from the wind. Annoying when everyday, the wind is at 10-20mph.
Image dump so you can see the vents I'm talking about. HDJ500 has 4 of them, 2 per side.
I think you can get away with just stuffing some foam or something there. Might help with noise reduction.
Edit: I did just clean out some dust from the tiny vents before I took that picture. Might be a placebo effect, but I swear the soundstage is ever so slightly wider.
