Podster
THX D, guess I could be a little more precise next time. I was wondering if the was the Black Star Wallet
If you get a better cable on those ue 6000 they sound amazing!
Especially with deftones for some reason
RWAK100 -> FAW Custom IC -> Vorzamp Duo -> ATH ES700's (with ESW9a pads)
Vorzamp is my dream portable amp...
i really want Pure II but can't afford it now
To your ears which Vorzuege amp does have best SQ?
i haven't tested Pure I or Duo but Pure II was the best sounding portable amp i've ever heard...
my experiences with portable amps is pretty limited though.
I can attest to the pure ii sounding absolutely spectacular, definitely blows the leckerton uha-6s mkii out of the water...
For about 70 bucks I got a 4 pole 6n silver 4foot cable from eBay from a Chinese seller, it's a vast improvent over the blue cable with the mic on it. Just make sure that you ask if it fits the ue 6000 because I've had issues with other cables in the past not plugging all the way into the 6000's, it's jack is at an angleWhich cables would you recommend?
