Discussion in 'Portable Source Gear' started by ringingears, Oct 26, 2012.
429 430 431 432 433 434 435 436 437 438
440 441 442 443 444 445 446 447 448 449
  1. kingice10
    X2 Mass Kobo is really an excellent amp...I compared it to the Ko Jo KM. But I have not compared it to my RSA amp.
  2. rudi0504
    You prefer Mass Ko Bo 385 than Ko Jo KM - 01
    What kind of source and headphone or iem did you use ?
  3. kingice10
    I'm using my JH16s when I tried in Jaben SG using J3 as DAP. The sound from the amp made the bass of JH16 controlled and more focused. The soundstage is also impressively wider. The resolution became better from a very good stock resolution of J3-JH16
  4. rudi0504
    I am agreed with your impression
    Did you heard hiss in your Jh 16 ?
  5. rudi0504
    I tried to reduce the hiss use my Er 4 P 75 ohm Adapter .
    The Result for hiss is very good , almost gone the hiss
    But this 75 ohm adapter reduce the SQ from Ko Bo a lot , the SQ now like
    Mono amp hahaha:D
  6. ExpatinJapan
    Ah good. I have etys 75ohm adapter too and it reduces the sound quality to my ears too.
  7. rudi0504
    Long time I never use with my er 4 p , with 75 ohm adapter can change to er 4 s
    Since this 75 ohm adapter reduce the SQ , I never use it anymore.
    Unless tonight as I try to reduce the hiss from Mass Ko Bo 385 .:D
  8. AnakChan Moderator
    @Rudi, you know you're missing the MH Audio HA-11 right :wink:?
  9. rudi0504
    Good morning Sean
    Yes it is you are right I miss MA HA 11, because in Indonesia only my best friend has this amp .
    He said the SQ is warm and detail
    In low gain got hiss
    But funny think in high gain ZERO hiss
    If you have time to compare please share here
    Between these 4 high end Amps
    Wagnus Epsilon S
    Ko Jo KM - 01
    Mass Ko Bo 385
    MA HA 11
    Thank you
  10. CosmicHolyGhost
    one more Japanese amp to put under the radar....... decision decision decision.....
  11. VisceriousZERO
    i just tried the MAHA11 and it sounded amazing... i just dont like the 2x 9v haha...
  12. CosmicHolyGhost
    Great... Possible to elaborate a little....? Thansks
  13. H20Fidelity Contributor
    I really enjoy this pairing, I've been using it everyday recently. Rather attached we're together.
  14. miceblue
    ^ that's a beautiful photo
  15. DMinor
    Just made a gold LOD, yes gold both the plug and the two channels - well not 100% gold. Used two copper wires for the grounds (pin 1 & 2). The silver/gold from Qables, the copper wires from Plussound and Homegrown Audio respectively. Yeah I know you don't need two grounds but I want to try different things.
    This thing doesn't sound bad. I mean not too bad. [​IMG]
