Discussion in 'Portable Source Gear' started by ringingears, Oct 26, 2012.
  1. alvinmate
    AK100ii friends with DITA!  [​IMG]
    "Pelican 1015 case - perfect fit"
    White Lotus likes this.
  2. ajs6269
    [​IMG][/IMG] image.jpg
    thundergod likes this.
  3. AUDIOBREEDER
    Does the earphone also fit in the case with the AK!00ii?
  4. alvinmate
    No it doesn't as you can see from my last pic. In saying that if you are after a similar type of case you may want to look at models like 1030 or 1040 depending on what you want to carry in the same case.
    A better pic - its a 'snug fit' so no movement inside at all.
  5. philk34
    I use this case too. I just add a piece of cloth at the bottom of the unit to avoid any upside down move that could put pressure on the volume knob.
  6. alan_g
    Ak100mkii>chord mojo >ak Angie
    Podster likes this.
  7. bluedolphin
    What Dap is the one on the left?
  8. howdy
    Looks like the iBasso DX100, a old but well respected DAP!
    bluedolphin likes this.
  9. gordec
    [​IMG]
    Cowon Plenue 1 with Westone ES60. Analog sound in the pocket.
    Sent from my SM-N920V using Tapatalk
    AeroSatan likes this.
  10. Darren Cotter
    Questyle QP1R and Fidue A83.
  11. ph0n6
    My "Transportable" rig [​IMG]
    reddog likes this.
  12. thepooh
    I saw the standard Dita for something like $600 on Penon Audio. I'm very curious about this little thing, how it sounds compared to Sennheiser IE800 or anything else in this range?
  13. Bengkia369
    [​IMG]
    LordJesus likes this.
  14. reddog
    Delete.
  15. alvinmate
    Great pic great artwork[​IMG]
