calipilot227
Ok I realise I suck at product shots
It's really hard (if not impossible) to make the Edition 8 look bad
Is it actually wise to carry the Ed. 8 around in public.
It's really hard (if not impossible) to make the Edition 8 look badThis is my favorite shot.
My recently completed rig
I meant the actual value that you are carrying around with you....
to me they also look prone to scratches.
I thought you were going to go with high voltage 220uF caps? How does it sound with the bigger caps? I did some reading, and it states the following about large electrolytics:
Reportedly types with higher rated voltages do better in terms of distortion when used as coupling caps (they usually have a lower DF, and their thicker oxide layer means that they'll survive longer unbiased time spans without becoming leaky – you don't want your precious signal currents to be used for stuffing holes in Al2O3 layers). The findings of Jung suggest the distortion generation mechanism to be related to current through or at least signal voltage drop across the capacitor.
Outstanding photography work! If you don't mind, I added your photo my album archive.
