tolis626
Ah, a video would be very appreciated!Just go slow. pull a edge over the side, hold on to other edges, kep turning, going slow, when you pull the earpad over the very top point is where it gets easier. i really need to make a youtube video showing how to do it.
to remove the 9500S stock earpad, you just take a corner, then take the corner next to it, and just pull hard. it doesnt matter which corners just create pressure on two end points. pull hard, and it pops right off and pops right back on too. some youtuber used a knife to remove it, destroyed the stock earpad. sigh.
Yeah, seen a lot of people do that stuff. I mean, if I need to take a knife and destroy the stock pad in the process, I would consider the stock pads not replaceable. The tab system Philips uses isn't the best, but at least they're not glued on. I hope the pad mounting would get standardized at some point. I don't even really like the normal rubber band pads like the HM5, but these at least work more than 1 time. Velcro or magnets would be cool, although I could see why magnets wouldn't be ideal for a headphone.
