DanWiggins
Member of the Trade: periodic audio
- Jan 30, 2017
For me, I am a HUGE fan of polymers, for a variety of reasons:Hello Dan,
If cost is not an issue, what would be the ideal housing material for IEM drivers in terms of performance? Polymers, or metals, etc? Thank you!
1. Weight. The NUMBER ONE source of ear fatigue for IEMs is weight. It's something that is heavily optimized with hearing aids, since those wearers tend to use them for 12+ hours a day. Weight is the killer of your ear; given that most polymers are less than 1.2 g/cc - less than half that of aluminum, and nearly 1/4 that of titanium - a polymer is a great choice.
2. Acoustics. I love materials that are rigid to resist flexing and having energy put into them - but then dissipate that energy when it happens. Metals are stiff, but to keep weight down you make them thin. Stiffness goes with the cube of thickness, so you lose a lot of stiffness when you cut the weight in half (stiffness drops by a factor of 8 for a weight reduction of a factor of 2). And then metals are REALLY BAD at internally damping energy. That is the reason there is a big push towards beryllium, it has really high internal damping relative to other metals.
But all metals fall FAR short of polymers when it comes to dissipating energy internally. Polymers just "damp it out". And that means it doesn't ring. You make bells and cymbals out of metal; you don't make them out of plastic for a reason! It's not because of a lack of strength (bullet-proof glass and fighter jet canopies are made from polycarbonate, after all), it's because they are really dead. So WHEN you get energy into the body (which will happen - regardless of the material used) it doesn't ring and send it all right back out.
This is also the reason that Baltic birch is so prized in most high-end speaker assemblies, or laminations of multiple layers of wood materials. They have very high internal damping and really don't ring. They kill the internal energy really well.
3. Comfort - temperature based. Hot or cold, metal is a great conductor of heat. Cold days, who wants to put ice cubes in your ears? Plastics/polymers are usually thermal insulators (you have to do special stuff to them to make them otherwise) meaning they take on your own body temperature. They won't be cold or hot - they just are. That adds to the comfort when wearing outside - and I see that as a the big strength of IEMs over cans - you can use them conveniently when outside and on the go. Easy to tuck away, easy to store, still sound good - and if properly designed, they are great at noise isolation (what some call "passive noise cancellation" which is, in reality, a non-sensical statement).
4. Cost. Tooling for precision injection molding is NOT cheap, but once it's done, you can replicate injection molded parts quite affordably! Metal is either machined (best, high tolerance that approaches injection molding, but very expensive and slow), injection molded (even more expensive tooling AND the per-unit cost is much higher than polymers, but still lower cost than machining), die-cast (affordable tooling, lower tolerance, only suitable for some alloys), or stamped (affordable tooling, decent precision, low cost to reproduce - but really low fidelity in what you can realize). Yeah, we COULD do machined titanium bodies and have them heavier, more acoustically resonant, less comfortable, but the cost would easily shoot up a factor of 20 or more, and that Be would no longer be a $299 unit but a $799 - and do we need Yet Another $800 IEM?
So, overall, I like polymers. And we use them, exclusively. We use polycarbonate for the bodies of our IEMs because it's low density, very strong, high internal damping, and really easy to mold, as well as allow for affordable IEMs. What's not to like?
