YtseJamer
Is the cable removable on these? Cuz... from the photos it doesn't seem to be. That's a big deal.
No you cannot remove the cable.
No, sadly it's not.Is the cable removable on these? Cuz... from the photos it doesn't seem to be. That's a big deal.
Actually you can. It just would require some specific skills and probably will cease the warranty (not shure about that). I've talked with the service-centre of my local auodiostore. They deffinitely can install the mmcx-connectors on Be for a small price. Thinking about buying Be at last and using them with my CB13.No you cannot remove the cable.
Well, unfortunately, that's a no-go then. There is no way in hell I'm dropping that kind of money on something where the weakest failure points can render the entire product unusable. Sad, I've heard great things, especially for a metal fan.
It always goes down to some personal stuff. You hate what you hate. I hate the word "can't". It always makes me angry when someone else makes the decision what do I actually need. So unless my actions hurt someone or someone's property I always try to overcome those limitations. Like installing mmcx-connectors on my earphones or making a jailbrek or unlocking all the hidden features. Just a little manifestation of my very own image of freedom.Oh stop. By that merit every phone has a "removable battery," too. I really hate it when people go "oh actually it does have that feature, you just need to physically implement it yourself."
But than again I probably should just leave you witj your hatred after all. As geting orders is also something I really do not appreciate.
It's ok. And my apologise too for been... well, can't find the right word so be free to choose any you like)EDIT: Look, I'm sorry I was being snippy. My point here is that when someone discusses a given feature, it's understood that they mean "by default." Yes, you can jailbreak a phone and modify hardware, but if someone is asking about it, they aren't talking about adding that feature themselves. If they were the type to do such mods, the question would be redundant.
Didn't mean to make you feel you or anyone else should be able to do all those things. My innitial comment was ment to say there is a way. Just not the easy one. Because sometimes there is actually no way to change or upgrade your gear. Like there is no way to change a graphic chip in your laptop.
I for one totally understand your dissappointment as i really think replacable cable is a musthave. Even a really good one (like those attached to DITA) tend to die as time goes. And then there are pets...
