Hi Guys
I purchased the AKG K702 headphones to replace my PC gaming audio setup ( Astro A40 + Astro Mixamp ) I used the Dolby headphone button on my Mixamp all the time and I'm quite used to it. Currently I'm running my AKG K702 through the onboard soundcard to the Astro mixamp and I can get the dolby headphone to work but its fairly quiet.
So in turn I've ordered the Mayflower Desktop Objective2 AMP to help with the audio levels. My plan is to use the AMP along with the astro Mixamp so I can still have my dolby headphone setup.
I also have a Xonar DGX soundcard and it does have the option for dolby headphone etc but it does nothing when I click it. I'm guessing this is because I need to run through the spdif into a DAC ( which right now is the Astro A40 ). I would like to sell the Astro setup but I don't want to lose my dolby headphone option.
Is a DAC required for dolby headphone to work? There is a version of the Objective2 amp that is also a DAC -- it's not too late for me to switch.
The help is much appreciated !
Thank you !
EDIT : 1) My on-board soundcard doesn't have the dolby headphone option in the software but I'm able to get the DH through the mixamp -- Is the sound card sending the audio signal to my Astro mixamp ( DAC ) and the Astro mixamp is creating the dolby headphone?
2) Which means since my soundcard doesn't have dolby headphone I would need to use the Xonar DGX soundcard with the dolby headphone turned on and connected via spdif (optical) to a DAC which would send the dolby headphone audio through?
In conclusion, if #2 is the correct way it works is there really any reason for me to purchase a DAC if I can just keep the Astro Mixamp that will do the same thing? The audio quality of on-board vs xonar might be a slight difference but probably not too much. I might be able to just return the xonar DGX and use my on-board sound with the astro mixamp.
Thanks again all !
Thank you !
Thanks again all !
