P4 the Warbler a new portable amp from iBasso . . first impression pg 3 . images Pg 6&7 . . .
post-8082775
Post #406 of 561
SpudHarris
That looks great buddy. I definately want one for my P4 and PB2. I wish I could source one of these knobs from the 2Stepdance.
post-8082792
Post #407 of 561
Huxley
Yeah i've seen similar on ebay, but they have three bands and appear to be too big.
Anyway i have these two yet to arrive.
http://www.ebay.co.uk/itm/190626696351?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
http://www.ebay.co.uk/itm/120751739842?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
The latter might not fit, we shall see.
post-8100436
Post #408 of 561
CJG888
Braunschweig
Braunschweig
I am thinking about getting a portable DAC to go with my QLS QA-350 and P4 (ideally, it should also work with an iPad2 via CCK without external power). Which would, in your opinion, make more sense - D12 or DB2? The latter seems more attractive, as I would not be paying for an amp I don't need, and I would have the option of going balanced in the future. Would it be overkill to buy a DB2 for single-ended operation? How do the DAC sections of the two units compare, and are they substantially better than the QLS' onboard DAC?
post-8101080
Post #409 of 561
paulybatz
I had a cable made to go from HIROSE to mini out for my DB1...also the D7 is a fantastic DAC unit too
I use the D7 and P4 combo all the time now
post-8101786
Post #410 of 561
CJG888
Braunschweig
Braunschweig
Thanks for the advice. As you have tried both, which sounds better: DB1 or D7? Unfortunately, AFAIK, the D7 cannot be used with an iPad2 without a powered USB hub, though
post-8102415
Post #411 of 561
paulybatz
Ill have to do some A/B'ing this week for you...but perhaps answered the ? if your IPAD is going to be a main source
post-8117192
Post #412 of 561
Huxley
Does anyone know of an omp amp config that'll raise the treble and tighten the bass, maybe even widen the soundstage a bit?
post-8135180
Post #413 of 561
jamato8
I would email or PM HiFlight. He has a handle on all of it and has some great kits.
post-8136499
Post #414 of 561
CJG888
Braunschweig
Braunschweig
I've found AD797s combined with wideband buffers and dummy adapters on the ground sockets works well for me in this regard. Could still do with a bit more treble extension, though.
post-8138920
Post #415 of 561
Huxley
Thanks, to both of you im in talks with hiflight who really knows his opamps.
post-8140507
Post #416 of 561
estreeter
Are you guys talking opamps or corporate takeovers ? You should ask his people to do lunch with your people.   :wink:
post-8142770
Post #418 of 561
Huxley
Well so do i, but i grab my yamaha EPH-100 more than anything else so im looking to improve what they lack in.
The P4 itself is a great amp, can't fault it especially at the price point.
post-8163712
Post #419 of 561
CJG888
Braunschweig
Braunschweig
Does anyone know if the P4 will drive the 600 Ohm HD 25-13, or would I be better off with the standard 70 Ohm HD 25-1 II?
My intention is to use them for listening to classical music (source will be an iPod Classic 160GB via Qables LOD). Listening to Wagner must be a possibility
 (IMHO it isn't via IEMs!). I know that the DT-1350s may be the more logical choice, but they are much more expensive....
post-8222992
Post #420 of 561
civilaudio
After searching the head-fi for combination and opamp orders...
my current second best for the P4 is AD8599 (class A)+ HA-5002(Buffer) + ISL 55002 (G/V)
Edit: After few hours of listening, I changed LT1355 in place of ad8599, this bring the sound stage closer to listener. I think this is the best now.
