edwardsean
- Jul 7, 2006
Hi @edwardsean ,
You can find the Mac version changelog here:
https://fongaudio.com/out-of-your-head-mac-os-x-version-release-notes/
The only thing we changed was to add the three new presets. The software and engine has not changed at all.
Are you running Sierra? Which version of OS X are you running?
We are looking into an issue in Sierra which might cause some audio artifacts while using other apps or menus, etc. But we have not seen that on every Sierra system we've tested. We have also not seen this problem on previous versions of OS X.
But running a lot of processes in the background can certainly make the problem worse depending on the speed of your hardware.
Thanks,
-Darin
Thanks Darin, I am running Sierra v. 10.12.2. As I mentioned, it could just be my system. As you know, I am pushing it pretty hard.
I am really looking forward to the new machine (grin). My current audio system has a pretty black noise floor, it stinks to have it all ruined by my laptop fan. That's my fault of course because of all the software I'm running on top of OOYH. If Audirvana would just support multichannel plugins, I would be set.
At any rate I ordered the new Mac mostly for my work, but part of the reason was to be able to run my audio software chain without fan noise. I hope it'll work out the way.
Please do let us know if the Sierra issue gets resolved. I'll chime back in to let you know if the new machine w/ Sierra fixes the digital artifacting.
